    Nov 2016
    Stevenage
    224
    IRS front brake pipes
    Hi normally you would have a front flexible going from chassis to a jaguar bracket on the front with a small hard line for the last few inches,into caliper. As per jag.
    at the time Dax sold me some front flexibles that go DIRECT into the caliper with a banjo/bolt and two crushable washers either side,
    does this sound right as spotted a leak on one of the banjos, tightened it but cant tighten any more. Seems ok but any one else piped in via this way, or shall i revert to the orginal jag xj6 way with bracket and short hard pipe and change the flexis?
    Got to be safe on this one.
    thx
    graham
    2,133
    AK use flexies and banjos right to the caliper, no issues.
    Is the sealing surface nice and clean and flat on the caliper?
    Jan 2014
    High Wycombe
    551
    AK Gen1 (not AK pipes).
    Haven't decided whether to fit them facing out at 90 degrees pic 1, or vertical pic 2. Just on loose as a practice fit at the moment until I've adjusted everything else. You may also notice I've not got any springs and shocks yet so might have to tweak positions when fitted, but no extra pipes as in the Jag (XJS) just straight to the caliper.
    Graham.
    Apr 2012
    Wrexham
    506
    Had to put a slight twist in mine, as you need to check the flexi is not fowling anything on full lock to full lock
    Gav
    AK Ls1/t56
    Body on April 2014
    Passed IVA March 2017
    Registered April 2017.
    Nov 2016
    Stevenage
    224
    Ok thx for the advice, mmm will check if flat as calipers were zinc plated, so may not be smooth. Tricky access to get flat. Hence why i was thinking no harm in reverting to the old way screw unions in with flared pipe.
    Also did you have to add a little p clip or something to the upper arm to keep flexi away from suspension? Or as you say a slight twist?
    Mar 2009
    liverpool
    354
    Most motorcycle calipers have banjo bolts with no issues?
