    Jul 2010
    Chesterfield
    254
    Odometer setting
    I'm sure somebody must have done this, so here goes.
    I have bought a new speedo.
    The smiths one with the digital odometer and trip. (as My old one broke and I never had a trip meter before so thought I would treat myself)
    I would like to set the odometer to the correct mileage of the car. at around 18,000 miles.
    I know some people who would like the thought of it reading less, but that's just not me.
    Anybody know how to do this ?
    I asked this when buying and they said that it was not made to be 'settable' as this would be open to abuse.....which makes sense.
    Will I have to set it on the bench and get a metal fan or something to trigger the speed sensor for a week or 2 ?
    What happens when I disconnect the power?
    Hope someone will have a better answer than me.
    9,578
    A couple of years ago I replaced all my gauges with Smith's Flight range. Like you I wanted to retain the correct mileage so I connected it to a signal generator and ran it at max mph for I over a week till the 40,000 odd miles were correct. No point trying to do it any faster as if you went over the max speed it just stopped registering. Of course this is only with a digital setup.
    Jul 2010
    Chesterfield
    254
    Thanks for the reply.
    Signal generator?
    For us non techies, what signal and where would one get such a thing?
    9,065
    Quote Originally Posted by gd427man View Post
    Signal generator?
    https://www.amazon.co.uk/slp/functio...6ezhka8ggro9xj
    - or if you are friendly with a locla school doing A level electronocs or tech college, they'll have loads.
    Set to square wave, probably 3/5V but you can check what your speedo sensor puts out to confirm.
    9,578
    Signal generator?
    I've got one at work and it just generates a square waveform, I just adjusted the strength till it registered a speed and then changed the frequency till the speed was at the max indicated and that was it.
    Jan 2004
    Southwest, Somerset, U.K.
    36
    3,265
    I’ve had it done a few times by Etb when restoring or replacing gauges. Simple process and John at Etb happily sets it to the number you want at the time if ordering. I’m sure the principle is the same for smiths
    Might be worth giving John at Etb a call. He’s a very knowledgable chap and always happy to help.
    Jul 2010
    Chesterfield
    254
    Many thanks for the replies chaps.
    I'll give John a ring and see if he can help. Not sure I know anyone with a signal generator but I'll ask around.
    Ian.
    Billericay, Essex, England.
    890
    Hi Ian,
    I got my digital Smiths speedo mleage set by the manufacturer... https://www.caigauge.com/
    That said, I did buy it direct from them and asked for the mileage to be set before delivery.
    May be worth an email to them to see if this is something they can help you with?
    Sean
    Too many idiots, not enough villages!
    Jul 2010
    Chesterfield
    254
    Thanks Sean.
    Wish I had done that in the first place.
    I asked Merlin motorsport if they could do it but as a sales outlet I guess they don't have the same facilities.
    I'm away on my jollybobs soon but will be on it when I get back.
    Thanks gents
