Results 11 to 20 of 31
    May 2014
    770
    Thanks Aaron,
    Is anybody running a non de-rated diff, have you experienced the above?
    Alan.
    P.S in touch with Ben and Russell.
    AK Gen II on the road Jan '19
    Tremec T56 Terminator.
    3.27:1 Powr-lok LSD
    931
    I don't believe mine is derated as there is no mention of this in anything I have from the kit manufacturer. Also, it passed that 40 ft-lb test. A reduction of 5 friction surfaces to three ought to have reduced the torque to about 24 ft-lbs, which is wasn't. I ought to re-do that test to be sure as it was a while back. At any rate, I havn't had any of those problems.
    When my kit manufacturer first started out they were using E-type rear suspension. From what I found on line, an e-type weighs about 2810 lbs, where my car weighs about 2550. Not a lot of difference,, especially when you consider the E-type was probably nose heavy and the Cobra is close to 50:50. This may put the weight on the rear wheels very close in comparison.
    E-type rear suspension was becoming more difficult to find, so they switched to a XJ sedan system which they narrowed. no mention of derating in my manual where they talk about selecting a unit. Doing a quick Google Search, I found a sedan weight of 4025 lbs. Anyone know if the differential was the same for both the XJ and the E?
    I'm sorry I couldn't post anything more definite, but it's a little food for thought.
    9,578
    Quote Originally Posted by AKCobra View Post
    Thanks Aaron,
    Alan.
    My friend built his Cobra with a non de-rated diff and it didn't corner well as said it just tries to continue on in a straight line, but when I applied slight throttle half way round a bend it got much worse and scared the life out of me (partly as it wasn't even my car). Diff came straight out and a de-rated one went in and it was a completely different car so much nicer.
    May 2011
    Flimwell
    866
    I had a de-rated LSD and found it quite unsettling especially in the wet. Swapped it for an open diff and it feels much more stable & predictable. Only downside i can see is that you can’t deliberately spin both wheels for 11s or doughnuts.
    Colin
    May 2014
    770
    Thanks Martin appreciated, going to get Ben to de-rate mine before it go's in.
    Alan.
    3.27:1 Powr-lok LSD
    May 2014
    770
    Lol, Colin your a man to my own heart!
    Alan.
    3.27:1 Powr-lok LSD
    Nov 2016
    Stevenage
    315
    Yeah i installed a salisbury dereated 288.1 P/L done by ward engineering, not IVA’d yet so cant comment. Not sure if ratio too low though. Its a powerful 289 Ford engine but with 4 speed. Guess i’ll suck it and see.
    4,270
    2.88:1 with a 4 speed should be perfect.. I have a 2.88 with a 6 speed, I guess I'll find out if it's too low for 6th
    Oct 2010
    kent
    I changed the the gearbox to a Tremec Magnum 6 speed which helped with the big jump and as I’m wasn’t interested in top end speed this gives me about 2000rpm at 70mph so not bad, probably a fair bit higher with a five speed. A real bugger to install though the chassis had to adapted. I did ask the forum if anyone had installed one to their Dax but only a few had fitted a GM t56 and thinking the should be the same size I shipped one over from Summit Racing and guess what it’s longer and wider, but no regrets the 4:09 and Tremec works brilliantly. I recon 3:77 married to a 5 speed would work well but not many about. Cheers Andy.
    Hilperton,Wiltshire
    2,608
    Isn't a 2.88 a high ratio?
