    Jun 2016
    Nantwich Cheshire
    320
    Side Vent and Brake Servo
    I’m in the process of finishing my engine bay, wiring, throttle cable, hooking up brakes etc.
    It has occurred to me that the driver’s side engine bay air vent will be impossible to remove and refit with the brake servo in situ..
    Am I missing something or will I have to remove the servo prior to paint just to get at the air vent ??
    9,599
    Quote Originally Posted by incey1966 View Post
    Impossible....NO Nearly Impossible.....Yes
    It can be done I have done it several times and it's really awkward but as long as you fit them as AK suggest you should be OK.
    Jun 2016
    Nantwich Cheshire
    320
    Ok Cheers,
    More knuckle scraping and expletives then.....
    I think I'll trial it before I fill with brake fluid...
    Dec 2013
    Newark, Notts
    70
    1,612
    Yep, I have done it as well and is is a b-----r but can be done. I had one come off as I had only used P38 to bond the wooden frame to the body. I retrieved it and cleaned it up and used P40. Been ok ever since.
    Charlie
    2,357
    If you can undo the fixings, the stainless grill will come through the hole if you’re careful.
    Jul 2014
    Longridge, Lancashire
    275
    Hi, I'm also just fitting my vents at the moment too. I've added a couple of aluminium angles on the inside above and below the vents. The angles are bonded on with Tiger seal adhesive. The vent is then screwed from the outside to these angles. I'll probably glass the angles on too shortly.
    You just have to be careful how you slide the vents in through the hole once it is painted.
    The vents can be fitted through the aperture and then pulled back into the hole.
    Hope this helps.
    Stu
