Page 56 of 63 FirstFirst ... 6465455565758 ... LastLast
Results 551 to 560 of 622
  1. #551
    4,924
    Thanks both! I was over-thinking it, thinking that the Ignitor had to be 'timed' to the distributor body somehow, but of course it doesn't, it's timed to the rotor arm (effectively) so as long as #1 is still #1, #1 is #1. Er.. made sense in my head, anyway; if it doesn't fire or coughs flames out of the carb, I'll know I've got it very wrong!
    My advice is pay the £1600 and get them done properly. It’s a tricky job and you could get very frustrated!!
    Yeah, I was having a look again tonight and cutting out the footwell didn't really seem to gain me any meaningful space, so it's just as difficult packaging-wise as it was before, and I'm very tempted to farm it out.. of course I expect the £1600 to be more like £2000 by the time all is said and done as it'll need transporting there and back, and prices have probably risen since last time I asked! I do feel a little sad, though, that I wouldn't have done that part myself.
    Weekend away from home this weekend for the OHs birthday, but I got down the garage today and:
    Popped the carb on - at least now I can get the throttle cable made up and attached, and figure out the fuel lines:
    Clocked the dizzy and got the header tank on:
    I will still need to make up a spacer, though, as the dizzy and header tank are rather intimate right now:
    I also ran the final leg of battery cable to the starter motor and started wiring up the alternator and other bits on the engine (temperature sensors, oil pressure etc) and started re-routing the fuel lines around the gearbox. Reasonably productive day..
  2. #552
    9,599
    yup, looks similar to what was happening on mine. Reckon a 10mm spacer and you should be fine.
  3. #553
    4,924
    Hm, it's been a while since I updated, but I haven't been (completely) slack.. in fact, I've finished wiring in the alternator (not a 1-wire so several wires and grounds etc) and got all of that tidied away. Wired in the starter motor trigger and got all of that plus the main battery cable clipped away.
    I then took care of the last leg of fuel line from regulator/filter to carb:
    Annoyingly I couldn't find black long-length carb fittings anywhere so ended up with blue.. I'll track some black ones down eventually. They need to be extra long in order to clear the vacuum secondaries linkage on that side.
    I'm hoping I don't need to P-clip the remaining length of fuel hose to anything as there isn't much to clip it to - I could lengthen it and take it to the firewall, then P-clip it there, but that feels like I'd be overly constraining it given engine movement/vibration, to me.. IVA examiner may disagree, of course!
    I made up that spacer for the header tank:
    Was remarkably easy in the end - I've somehow ended up with several of these elbows:
    So I just lopped one off at the joint (hacksaw, took seconds) and then faced it off in the lathe to make it flat and parallel. Sanded the chrome off and painted it flat black.. should do and now the distributor clears the header tank.
    Things left on the list now are:
    Coil and pressure/temperature sensor(s) wiring on the other side of the engine
    Coolant hoses (inc. heater hoses)
    Throttle cable
    Headers
    Maybe re-do the dashboard
    Carpets
    IVA test
    One of those is a big job, and the last quote I had was £5000 so.. er.. gulp? Seems everyone is busy making exhausts for the classic race circuit cars (BTB have done exhausts for real Cobras and GT40s, Ollie has done them for historic Formula cars) so is both booked up for months and eye-wateringly expensive!
  4. #554
    4,924
    It feels like not much has moved on, but little bits of progress here and there.
    The coil, water temp, oil pressure & temp sender wiring is now all complete and secured per the regs.
    I've moved the remote oil filter down a little bit and forward a touch to clear the underside of the bonnet and give a bit more clearance to the coil & radiator pipework.
    So the pre-start to-do list is still:
    Radiator pipework & heater hoses
    Throttle cable
    Headers
    Those damn headers..
    Still, I did finally use the mill for something (slotting the mounting holes in the oil filter relocation bracket):
  5. #555
    1,725
    That's handy having a milling machine to do brackets and small parts. Not all of us have a lathe and milling machine lol. Small steps and progress. I bet this weather makes all the difference. Maybe to hot in the garage but great for driving out.
    John Desz
    Essex & Herts Area Rep. UKCC
  6. #556
    4,924
    I started off using the drill press and a file .. I wasn't sure about using the mill 'in anger' so to speak as it still needs a new X-axis feed nut carrier, but it turned out so much faster and neater I wish I'd started off with it now! Very handy indeed.
    Bit more progress today after spending all of last weekend swearing at the tin top:
    Mocked up both upper and lower radiator pipes (lower shown) in snap-together 3D printed plastic blocks and ordered up the aluminium tube & bends to TIG together. I thought this seemed like a nice easy intro into that kind of fabrication before I think about trying those headers on for size..
    The plastic blocks are smaller in diameter than the aluminium will be, but got me in the ball-park and knowing what bends I need to chop up. Just have to wait for the delivery now!
  7. #557
    Mar 2005
    1,237
    IIRC my headers, collectors and sidepipes from Custom Chrome were around £1,600. Still ouch, but less so than £5,000.
    David (AKA Firestarter29)
  8. #558
    4,924
    Considering that includes the sidepipes, that seems like a bloody good price! And he's not a million miles away, either.
    I have been spending time on the radiator pipework the last few evenings, and it's starting to come together nicely now - I'm definitely picking up speed the more I do it.
    Step one was to run some beads on flat plate and progress to a butt weld once I'd got a feel for the AC TIG again (I always forget how violent striking the arc feels on AC, and it took a bit to get gas flow dialled in and get the hang of puddle control again as it's completely different to steel):
    Then I lopped off a couple of 3" lengths of straight and stuck those together - I was actually really proud of this joint:
    Chopped up the actual bits of pipe - this took a couple of iterations with some adjustment but the plastic modelling blocks helped enormously. Having done that beautiful (for me) test weld above, naturally the first actual weld I did looked like shite in comparison but it's sound, at least (top left most weld, here, between the reducer and first elbow):
    Then I accidentally made a hole while tacking (bugger):
    So I made up a steel 'backer' using some close diameter steel bar out of the scrap bin and welded that hole right up:
    I was pretty proud of that, too! Couple more sections to tack on this evening and then I can test fit it and finish weld it assuming it's all good. Then it's the (shorter, easier) upper radiator pipe to do.. I'd forgotten how much I enjoy TIG welding, though, it's incredibly therapeutic (for me)!
  9. #559
    9,599
    Good work!
  10. #560
    Feb 2013
    418
    Seconded. Great welding indeed!
