Results 1 to 10 of 23
    Feb 2005
    Reading, Berks
    342
    Oldie returning again to try and finish build!
    Hi all,
    After another very long break, (4yrs l think), I have just started to look at the car again!
    Its a Pilgrim with RV8.
    Originally started in 2005, so l must be one of the longest builds!!??
    The list of jobs is still quite long!!
    The first is to get the engine running again. I had left water in it during a summer test of the engine which had frozen. The good news is the engine doesnt seem to be cracked but 2 core plugs had popped and the heater matrix has split.
    Plugs replaced and the engine has fired up, l was surprized!
    When l started this SVA had just come in l think, of course thats come and gone. I'm having to go over things again now for IVA and have various issues l know of already to sort/replace.
    Its hard enough getting back into this without having to redo things too!
    Anyway, have to start somewhere so first post in Pilgrim section done.
    When will it ever be finished??!
    Hopefully better luck 2nd time round!!!!!!
    Or now the 4th time round......!!
    8,637
    Well done.
    Assume this is a rolling chassis with an engine...or is the body on?
    Pilgrim has now changed hands, and is a very professional operation.
    But all the usual bits are available.
    My Sumo took nearly 10 years, Crendon not dissimilar ....but def worth it.
    Essex, UK
    3,910
    There’s a 28 year build on here somewhere....😳
    Mar 2005
    BERKSHIRE
    629
    That's nothing I now on 32 years of a build of a Dax ??
    202
    Good God 32 years !!!!
    And I thought 8 years was too long.
    You'd better get a move on, you've only got till 2025 to get it completed and enjoy it if the extinction rebellion cult nutters get their way.
    But they won't so build away.
    Baz
    Mar 2005
    BERKSHIRE
    629
    I see mr fawlty in reading same as me must be some thing in the water ?
    Feb 2005
    Reading, Berks
    342
    The body is fitted, just the inner sills and front part of rear arches to seal up. Then l can start fitting the interior.
    I have most of the stuff to finish l think, but there are some bits l don't think will pass IVA.
    Well it looks like I won't hold the record for the longest build then😂
    Whereabouts in Reading are you Oiler?
    Mar 2005
    BERKSHIRE
    629
    pm sent mr fawity
    Nov 2004
    340
    There's no rush Steve, as I'm sure you know yourself, just take one job at a time. I started in 2003 and just got it on the road last month.
    I had to recondition the Sierra brake callipers 3 times as they don't like being left. You can take them off and do them on a bench so not as bad as core plugs!?
    Its definitely worth it. The RV8 just sounds fantastic when its happy!
    Best of luck!
    Declan
    RV8, Sierra based Viper.
    Feb 2005
    Reading, Berks
    342
    I guess I'll probably have the same issue with the brakes!
    I did the clutch conversion, well the peddle part anyway but didn't get to fitting the slave part, so could have a similar problem there.
    Did you have to redo anything for iva?
    I bought the boot hinges at least 10yrs ago, l read somewhere they may not have the correct radius?
    Same with the fuel cap, bought from brasscraft. I think there's a screw on cap available now because of height and radius issues.
