Results 11 to 14 of 14
    South of Winchester
    181
    I found the circuit diagram for the tachometric relay on the web - I’ve got a copy in the garage that I could take a piccy of if anyone’s interested - no idea how to get it on here though!
    Nov 2004
    340
    This is the fitting out of my old Facet pump. you can see they thread in. If you think the pump is lost anyway, you could try cutting into the top of the aperture with a Dremel disc or a hacksaw to give a grove to screw it out with a large screwdriver.
    If it comes out, and matches this one, i'll send it over. There's bound to be a petrol proof sealant, that hopefully someone could recommend, to seal up the damage to the top of the fitting?
    Unless the whole port has sheared off??
    The new pumps, (I got a Facet Silvertop from Demon Tweaks with all the fittings for an RV8 on SU's and its going well) have a larger thread in the ports!?
    Declan
    RV8, Sierra based Viper.
    Feb 2005
    Reading, Berks
    342
    Again I can't see your pics for some reason?
    I'll have a better look at the pump and see if there's anything that can be done with it
    Feb 2005
    Reading, Berks
    342
    Fuel pump update,
    After your comment Russ, l had a better look at the pump.
    Its a Huco and the oulet is replaceable, cost 5.95, just found a supplier!
    I was so fed up when it happened l didnt look properly.
    Cheers Russ
    one job ticked!
    When will it ever be finished??!
    Hopefully better luck 2nd time round!!!!!!
    Or now the 4th time round......!!
