Results 1 to 7 of 7
    678
    Radiator mounting rubber thingies!
    Rubber top hat mounting things that fit the pegs on the top and bottom of the radiator.
    I need to find some with 10mm I/D, plenty out there (Land Rover, Rimmer Bro's etc) but can't find any with sizes. Any one know which are 10mm ones or are they all the same/standard size?
    Thanks, Graham.
    2,934
    is this for an SD1 radiator, if so try rimmer bros:
    https://rimmerbros.com/Item--i-NRC5544
    rgds
    678
    Hi Gary,
    looked at these already and are possibly what I need but not sure as no sizes!
    Radiator is a Nissan 200SX 50mm core, so I have had to re do brackets and the like to fit. Pins/pegs top and bottom on the rad' are 10mm diameter so just trying to find mounting rubbers to match, holes in the bracket aren't a problem as I can drill them to suit.
    Graham.
    Oct 2013
    southampton
    78
    I have Nissan rad and used these.
    https://www.ebay.co.uk/itm/Rubber-Di...72.m2749.l2649
    2,934
    iirc when i had one of the nissan rads, the rubbers from my SD1 rad fitted fine - i didn't in the end fit the Nissan rad as there was to much work needed on the rad cradle on the SR to get the Nissan radiator to fit.
    678
    Thanks all, order pending with Rimmer Bros'.
    Will try and post a couple of pic's when I'm done.
    Graham.
    Sep 2004
    Bressingham
    1,346
    Not entirely to on topic but a useful link nonetheless is a company called fibet.
    They make rubber bobbins in many permutations.
    Always helpful too.
    A
