Hybrid View
    Portsmouth, Hampshire
    340
    Spax damping adjustment on SRV8
    Been getting more miles on my car today and all going well having fitted my different oil take off adapter and keeping the oil in the engine rather than down the road! I have two questions for any SRV8 owners :
    1. I know every car is different but does anyone have any guideline base damping settings for Spax shocks on an SRV8
    2. Most of my damping screws are moving and clicking like I would expect but they are not reaching a stop point to count the clicks out from. They are adjusting because having wound them in my car isnt driving like a Cadilac any more. Anyone know of this problem other than telling me Spax are rubbish and I should bin them?
    934
    Not a SRV8 owner, but I have Spax shocks on my car. The first 4 clicks are not discernible, so you may not have actually reached bottom fully, but stopped as you weren't hearing clicks.
    It was recommended for me to set mine 5 clicks out from zero, although I firmed it up a bit later on by going to 7 on the rear shocks. Maybe a bit too firm. I intend to try 6. Again, for 6 clicks, you can't hear/feel the first four, so just remember that each click represents 1/4 of a turn.
    Maximum clicks on mine can go up to 15, probably for a much heavier vehicle.
    340
    Hi John,
    Thanks very muich for responding. I am used to setting up motorcycle suspension and in that case you always wind in to full in where the screw comes to a firm stop and then wind out and count the clicks (yes mine are 1/4 turn clicks). It sounds like you are starting wound out and winding in ?
    Mine were wound all the way out when I started and it did take a few turns for it to start to click.
    934
    Well.... no. I had forgotten it works backwards. So I looked it up. You are correct it works from "out" to "in". Here's a picture detailing two blurbs form my older and newer build manuals:
    Sep 2004
    Bressingham
    1,352
    You can apply the mid ordinate rule on these type of settings.
    First establish the range of adjustment then set midway.
    Test and make a decision on which way to go.
    Half the remaining amount of adjustment and set there.
    Test again.
    Half the remaining amount of adjustment and so on.
    Or just go by gut and give it one or two a time and test.
    A
    340
    Brilliant info guys ! Really appreciated. The problem I had is I was expecting a hard stop on the screw when it was wound in but that doesnt seem to be the case.
    The important info is there are 15 clicks of adjustment and you start all the way out on dead soft and start counting once it starts clicking.
    At the moment I am clearly on full hard which is much better than full soft but I probably need to back off to mid range again.
    Cheers !
