Results 1 to 3 of 3
    Mar 2019
    Sevenoaks
    112
    Parallel Bellhousing
    Just a quick one. I am mounting my bellhousing onto my 1973 machined cbs 350 block.
    I am obviously checking parallel before run out.
    My bellhousing is off by 2mm at 6o'clock. It needs kicking out.
    What shims have you guys used? I have googled and looked at some UK and USA sites but cant seem to find a product.
    Am i to literally buy some steel sheets of shim stock and cut on site and wedge in between the bellhousing and block?
    Once this is sorted i can then do run out and the offset dowels........
    Thanks Jules
    AK Cobra started 06/19
    Chevy 383 Stroker, TKO 600
    930
    2mm is quite a lot. That might require shimming up to 0.040" and that's if your 2mm is at the outer edge of the B-H. Ford says if it needs a shim over 0.010" discard the bell-housing. Couldn't find a spec for Chev. A quick Search didn't show up any Bell-Housing shims, but they can be made fairly easily from shim stock. Should be able to get that at a Machine Shop. Alternatively, you might look at the variety of shims for Chevy starter motor installations. They might work, but would probably have to be cut-off to shorten them.
    Now if it were me, I'd have the B-H trued parallel at a Machine Shop, presumably using a Flywheel Grinding Machine. The trick here of course is to know which side of the B-H is out. I picture it this way: If you were to use shims, it would tilt the B-H into being parallel with the flywheel. This will change the bore run-out as well. Back to the machining, knowing which side to fix might help with any bore run-out issues. The wrong side will make it worse.
    I'm still amazed you're out by 2 mm. Are you certain all the longitudinal play was taken out of the crank and kept out, while you were checking/rotatiing it? Also, paint blobs on the engine facing side of the B-H can cause trouble. The B-H must be torqued down tightly too.
    If you know all this, please don't take offense. I'm just trying to help a bit, but must admit I've never dealt with the out-of-parallel problem you have, just bore run-out.
    930
    Here's a couple of sources:
    https://www.grainger.com/category/ra.../slotted-shims
    https://www.mscdirect.com/product/de...32233?fromRR=Y
    The second link has other sets that might fit better, but they are all expensive. The first link might be easier on the pocketbook.
