Results 1 to 10 of 10
    Apr 2012
    Wrexham
    532
    Mysterious C clip...
    Hello,
    I found an internal c clip under the middle/front of the car.....on the floor....
    Hate things like this...
    Its like one of the squueze together ones that are normally in the UJ's.....
    I have checked the prop 8x clips..all there...
    I have checked the two x 8 clips to each rear wheel and all there...
    I have checked the steering shaft and not that as their too small a size and they are crimped sealed from AK anyway...
    Im going maddddd
    Any ideas?
    Some of the uj,s on the prop are circlips and some are squeeze type clips when i had the prop shaft shortened done etc.....
    Gavin
    AK Ls1/t56
    Body on April 2014
    Passed IVA March 2017
    Registered April 2017.
    3,899
    One that you lost years ago and has suddenly made an appearance?
    I took the other halfs MINI apart and not one but two M8 bolts fell out of the undertray.. they looked brand new and identical to the main ground strap bolt (weirdly, a through bolt on that car) - pretty sure the dealer/last person in there dropped not one but two, and they've taken this long (it's a 2007 car) to work their way back out again!
    Apr 2012
    Wrexham
    532
    Heres hoping......
    Cant think anywhere else on car, engine, gbox they have them.....and cant remember what i did 7 years ago when building it......
    Gav
    AK Ls1/t56
    Body on April 2014
    Dec 2001
    Cherval, France
    1,681
    Clutch slave cylinder ?
    Apr 2012
    Wrexham
    532
    Its internal, T56 LS1 so i bloody hope not.....
    Gav
    AK Ls1/t56
    Body on April 2014
    Dec 2009
    268
    Is your speedo electronic or cable it could be a blanking plug retainer clip on gearbox??
    Mark
    mark chambers
    Dax de Dion 350 Chevy
    Apr 2012
    Wrexham
    532
    Electronic vss in rear (t56).....
    Thanks all though.
    Gav
    AK Ls1/t56
    Body on April 2014
    Aug 2009
    586
    I would never drive the car again!
    It just does....
    2,301
    It might be mine; I had one ping off in the workshop a while back and I never did find it. Reckon it went through one of those space/time portal things and ended up in your car. You didn't come across any tape measures or pencils at the same time did you?
    Apr 2012
    Wrexham
    532
    Funnily enough......
    AK Ls1/t56
    Body on April 2014
