Results 1 to 10 of 21
    Jun 2005
    Norton Cross
    524
    Low oil pressure
    Took the car out on Sunday for a run and noticed oil pressure seemed low. Was running at 0.5 to 1 bar. Engine was at temperature.
    Seems low to me. Any ideas?
    Pete
    8,981
    what engine?
    did you mean bar or psi?
    1,705
    what engine?
    Got to be bar surely? 0.5-1 psi wouldn’t be detectable. Tickover or running speed?
    (1 bar = 14.5 psi)
    Jun 2005
    Norton Cross
    524
    what engine?
    Hi - It's a chevy 350 and showing 0.5 to 1 bar
    Jun 2005
    Norton Cross
    524
    (1 bar = 14.5 psi)
    was showing 0.5 to 1 bar when running at 2000 rpm
    4,242
    I'm no Chevy expert but that sounds awfully low .. I'd be "ok" with 10psi (~0.8bar) at idle, but it ought to build off idle with a rule of thumb being 10psi per 1000rpm - so closer to 1.5bar at 2000rpm.
    In fact, if it didn't rise beyond 1bar I'd be concerned about damage when running, so you really want to rule out the gauge (it might just be a false reading). What kind of gauge - mechanical or electrical? If electrical, digital or analogue? If analogue, is the voltage stabiliser working OK? Can you try a known-good mechanical gauge directly off the oil pressure sender port?
    1,351
    Pete, Aaron makes a good point. My mechanical oil pressure gauge is on the shelf not yet fitted if you need to borrow it to confirm what actual pressure you are getting.
    Jun 2005
    Norton Cross
    524
    Thanks Lee. I’ll take you up on the offer. Will give you a call later
    Jun 2016
    Nantwich Cheshire
    299
    Pete,
    I have a pressure testing kit if its any easier/closer.
    Jun 2005
    Norton Cross
    524
    Hi Mike
    Pressure testing kit sounds good. Wouldn’t mind getting one myself. Which one have you got?
