The Nissan 200SX radiator comes up a lot - I think that's the S14/S15 item rather than S13: https://www.ebay.co.uk/itm/45mm-CORE...T/351976100774
Size is 670x505mm according to that listing - I think that includes mounting lugs, though.
Readily available with shrouds, too: https://www.ebay.co.uk/itm/3-Row-Rad...T/233281252080
Looks like the S13 rad (for SR20DET engines) is damn near identical: https://www.ebay.co.uk/itm/3ROWS-52M...T/254268807201
But avoid the S13 CA18DET radiator as the inlet & outlet are on the same side (the right) rather than opposing - unless that helps in your application, of course.
[edit] If I remember, I'll measure the 'hole' it goes into on the Dax later.. I'm half tempted to change the Dax radiator to the shrouded 3-row above..
