Results 1 to 4 of 4
Thread: Rear hub nut
    Nov 2007
    Chester
    622
    Rear hub nut
    Anyone replaced the castellated nut on the rear hub with a nylock type. If so what's the thread size.
    Also, I've got 2 torque settings written down, 95 ftlb and 140 ftlb. Which one is spec
    Al
    Dec 2013
    Newark, Notts
    69
    1,524
    Is it Jag rear end? If so, ensure you use the correct castellated nut. These have an insert inside which locks the thread. If I remember correctly you need about 270Nm torque when tightening. The nuts are about £20 each and you should only use them once!
    Charlie
    Maldon Essex
    255
    I would NOT use a nylock all of that lot gets quite hot..... Why would you not use a castellated nut?
    Nov 2007
    Chester
    622
    Yep, thought about the heat andstayed with castellated nut.
