Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
    Lanarks
    211
    Worth every penny ££££££
    Anyone got this type of axle fitted ?
    Any ideas on the price?
    943
    That's Kirkham billeted aluminium rear end. Don't think you will be walking away with much change from 10k just for the suspension parts!kirkham20.jpg
    Lanarks
    211
    £10k you say.....just for the parts! YIKES
    ...and then to find someone to actually fit it.....and pay £££ MORE
    Q........ have an educated guess at what my rear axle cost me to build ?
    I like Airfix kits
    the fun is building/designing it yourself, having something different +saving a few pennies.
    943
    The suspension is a work of art with all the billet aluminium work. They use to offer an authentic suspension kit as an upgrade. Kirkhams are selling £120k plus.
    I would not even like to guess lol What is the diff as the cover looks very different.
    Lanarks
    211
    Designed it and built it myself.........I have this one left
    You can see where the costs mount up if you just credit card a fully built car.
    I copied George's idea on those bottom billet arms and had a pair machined up to my spec.
    My Jag IRS Quick-change was just to make it look a little bit different.
    Took me a month to make it. Cost me less than £10 in materials
    Imagine paying £40- £120k and another one turns up EXACTLY the same.......
    943
    That's why I like this site. So many talented people. You have a great eye for detail. Since you have done all the hard work on the design I am sure people would be interested.
    Lanarks
    211
    Let you into a secret……so ssssssschhhh don’t tell anyone
    Optional extras:
    Wiring loom:
    £500 loom v a £10 modified loom
    Never had a problem with any of my previous builds
    using a simple BL mini wiring loom….
    Those wee electrons still find their way along.
    Did you know a donor car Jaguar XJS battery cable
    is long enough to be used !
    Petrol tank:
    £400+ tank v a £100 Homemade unit.
    Much safer having it behind the rear bulkhead area than
    hanging out the rear only inches from fast approaching cars!
    I can't weld aluminium so had a chap build me an aluminium fuel tank from
    my AutoCad drawings.
    I first made up a Blue Peter cardboard box to make sure it was a snug fit
    in the boot space
    My floorpan might house a spare wheel…….
    Nov 2016
    Stevenage
    265
    Brilliant, i to made a copy loom with New wiring, connectors, relays and fuse box for about 110.00, takes a while but all works. Copied the original.
    with that fuel tank whats the small top outlet for, vent? As my standard dax tank, hose and aero cap does not have anything for a vent pipe and neither does tha dax or dax iva manual mention it.
    Lanarks
    211
    I'm using a flush fit petrol cap - Push to open then twist to remove.
    I'll need some vented hose going up and around then down to the bottom cannister.
    They'll be very little fumes.....as this cannae Scot only puts in 1 gal at the pumps and it lasts me for months.
    I like to use as much as possible from the donor Jag
    What is wrong with using calipers that passed an MOT under a heavyweight Jag?
    Are those U/Js servicable?
    Do the pads or discs need changing?
    Does it need caliper seals?
    Is there any wear or play in those bottom arms bushes etc
    Can that chromed XJS handbrake be used with its cables just shortened to suit.
    Renew and replace where needed
    Sticking front brakes anyone?
    Leaving your old Jag 4pot calipers for months can cause binding or stuck brakes.
    Pull out the pistons and have 8 machined up in stainless......pop down to the local polishers and have them mirror polished to perfection. Install with new seals
    All for about £100 the pair.
    Oh......my bias brake setup cost very little to make.
    I'll wager some paid more on VAT
    943
    Great ideas. I get so much more satisfaction by coming up with new solutions and off the shelf. I know if I make its a one off.
    I never had issues with brakes binding ( famous last words) . It could be because I am using DOT5.0 brake fluid which is none hygroscopic. Stainless is a nice solution to stop rusting.
