Results 1 to 7 of 7
    Dec 2019
    amersham
    35
    steering column to ak wiring loom
    Just trying to sort out my BMW E46 donor column wiring. I have removed the ignition barrel and associated wires but it is not clear in the instructions as to whether the plugs/sockets attached to the wiper and indicator stalks need to be cut of as well,i assume they do and then the relevant wires need to be spliced into the AK loom,is this correct.
    Any suggestions appreciated.
    Dec 2013
    Flackwell Heath
    90
    The plugs and sockets are used for connection, AK have put those sockets already on the loom, the wires not used can then be removed. No wires need splicing into the loom from memory!
    hope this helps!
    Mark
    AK gen2 ls3
    Dec 2019
    amersham
    35
    Mark
    Agreed that there are sockets already on the AK loom but they don,t match the ones on the BMW column wiring ,they are of a different type. Its a bit confusing.
    Mar 2010
    1,240
    As suggested the plugs are already on the AK loom. You might have to lock the wiper motor plug onto the motor connection by passing a small cable tie through the loom near the plug to prevent the cable plug from coming loose from the motor. I had to do this as others have suggested in the past having done the same.
    Apr 2014
    Stourport on Severn
    247
    From what I remember you end up cutting off the bmw connectors and making up some new ones using the connectors supplied with the AK loom. There are quite a few of the column wires that don’t get used so can be cut short/isolated.
    The wiring guide in the build manual covers E34 column, but many of us have had to use later models, mines an E36. The wiring is slightly different.
    if it helps, in my blog link below, find the section on Wiring Part 2 and there are some notes on the pin outs for the column. Might not be exactly same for your column but might provide some pointers.
    2,263
    As Steve says, I’ve just done mine.
    The AK wiring instructions tell you how to connect it in.
    There should be two plugs with crimps in the AK loom pack, cut the BMW plugs off and fit the AK ones.
    Dec 2019
    amersham
    35
    Thanks Steve
    That,s what i suspected, i just wanted to make sure because once they are removed then its a lot of work to replace them.
