Results 1 to 7 of 7
    Jun 2005
    Norton Cross
    524
    chevy 350 oil leak
    I've noticed oil the top of my chevy 350, just under the dizzy. I ran it up to temp on the weekend and can see that it's coming out of the connection where you take the oil pressure.
    I'm using a standoff here, that I then use to make a connection to oil pressure sensor and oil pressure light.
    The standoff is the correct fitting and is screwed in well. Any ideas what I can do to stop the leak?
    Pete
    1,610
    Been covered before. Search “Leaking oil sensor” and you’ll find the answer. Good luck in stopping it.
    Apr 2013
    Basingstoke, UK
    38
    336
    Kit has arrived.....follow my progress here at my blog:
    http://marksak427.blogspot.co.uk
    AK 427 Gen II
    Chevy SB 350
    Tremec TKO 600
    Well.....that's the plan at the moment!
    Welcome to the money pit......
    Mar 2008
    Coventry
    2,328
    It is more than likely the inlet manifold rear gasket seal leaking. Well renowned for it leaking from there
    AK, on the road Oct 2012
    1,610
    Quote Originally Posted by seph View Post
    Inlet manifold gasket leaking oil?
    Jun 2014
    Redditch
    110
    Yes, do check the inlet manifold at the back of the engine near the oil sensor. I had exactly the same problem solved with new inlet manifold gasket and a good quality sealant "the right stuff" recommended by an engine builder. There are a couple of good videos on YouTube that cover this job.
    1,610
    Ah I’m with you now and know where you mean.
