Results 1 to 10 of 15
    1,042
    What grade aluminium sheet to use
    What grade aluminium sheet should I use? There are so many grades available.
    The sheet needs to be malleable, corrosion resistance and I am looking to achieve a polished to a mirror finish.
    Radiator cowling - 2mm
    Boot sheeting and front nose cowling-2mm
    Centre Tunnel and back. 2mm
    Folding and pop rivets with minimum welding is my fixing method.
    Also is 2mm thickness fine for all these areas?
    STOKE ON TRENT, U.K.
    10,166
    1.5mm will be fine.
    1050 H14 grade should be fine for what you mention.
    If you are polishing it, then you can wax it to protect against corrosion.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    ALUMINIUM BODY, ROUND TUBE CHASSIS.
    ORIGINAL SPEC. SUSPENSION COBRAS.
    OEM style stainless SIDEPIPES
    Dec 2013
    Newark, Notts
    69
    1,535
    Agree with Dave, 1.5mm is ample. Not totally convinced on the corrosion side as aluminium does corrode quite easily. I would have gone with st/st and it is surprisingly cheap off ebay. 304 or 316st/st is best bet.
    AKCharlie - ''AKA SOOTY'' - AK GEN2 - LS3 - 6.2litre - 434bhp - A dream come true
    1,042
    Thanks Dave
    Charlie. I might use stainless in certain areas as should keep the shine longer. A bit harder to form I might need a small folder.
    10,166
    If you do go for stainless. Get 430 Bright Annealed. 0.7mm is much easier to fold than anything thicker.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    1,042
    Thanks Dave.
    Found this which seems very reasonable.
    Stainless Steel Sheet 333 x 333 x 0.9 mm type 430 Bright Annealed x 1 off at £18.00 a sheet. or
    Stainless Steel Sheet Bright Polish 0.9mm 1000mm x 500mm at £35.00 a sheet.
    I will be busy with my cardboard.
    4,053
    If you're going to attach sheet to sheet with rivets, or even welding, you might want to invest in some Cleco pins and pliers - they are next on my list for when I start doing the radiator & oil cooler surrounds.. relatively inexpensive on eBay (check out this seller: https://www.ebay.co.uk/str/skinpins/...at=26616944012)
    10,166
    That 0.9mm is a lot harder to fold than 0.7mm.... been there!!!
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    4,053
    Quote Originally Posted by dave View Post
    It's not a linear progression, is it.. there's probably some complicated maths that says it's exponentially harder the thicker the material is - that's how it feels, at any rate!
    OK, there is - page 16: https://www.dropbox.com/s/m28sftv7hx...27.25.png?dl=0
    I'll leave someone else to do the calculations
    1,042
    Aaron. I looked at the calculation and its like being back at college lol
    Working out radius bends and setting up on a fly press. I think that calculation is for die stamping lol
    That's interesting that 0.2mm makes so much difference for folding but I go with the Dave@s knowledge and experience. I could always use the 0.9mm if its just sheet area. I think most will require some folding or bending to a degree.
