They look like Dax sidepipes, Dax have been fitting the bracket like that for years, if you think about it once the pipe is fitted there is no way that the end cap can pull out of the pipe, in other words they will be fine as they are. AJMHO!
If they are Dax pipes then you might want to look into the 'reverse cone' setup that Dax use inside each pipe, it can be sorted out but is pretty bad in terms of gas flow.
