Results 1 to 3 of 3
Thread: MK3 toe in?
    Oct 2009
    Tavistock, Devon
    70
    1,340
    MK3 toe in?
    Can anyone tell me the measurement for a MK3 GD front wheel alignment please.
    Standard road use with 215-55-16" wheels and tyres.
    Thank you.
    Murray
    3,636
    Hi Murray,
    0.0 - 1.5mm toe in overall (0 deg, 15 Min)
    Camber is between 0.0 and 1deg Negative
    Caster is ~4deg (bit more if you’ve fitted EPAS though)
    GD J1M
    Oct 2009
    Tavistock, Devon
    70
    1,340
    Jim,
    many thanks, I had looked everywhere for the MK3.
    Found everything else and need to get the alignment done before I go too far.
    Great this forum, very much appreciated, thank you.
    Murray
