Results 1 to 9 of 9
    Mar 2009
    liverpool
    407
    Ground Clearance
    What's the minimum ground Clearance for UK driving?
    Feb 2013
    266
    As low as you dare? My county's roads are a disgrace so I have a sensible ride height - but used to drive an extremely low Beetle in my yoof...
    1,054
    Speed bump clearance height is required with a sump guard fitted. The minimum height should be 100 mm. The sump or gearbox housing is usually the lowest point.
    http://www.legislation.gov.uk/uksi/1...ulation/4/made
    the highest point on it is not less than 25 millimetres nor more than 100 millimetres.
    81
    I can't get 100mm on mine, probably nearer 70mm now. I fitted a Canton baffled oil pan before Christmas which lowered me another 20mm. Doesn't sound a lot but I was already low enough! So I made up an aluminium sump guard and guess what, there are a few little marks on it already, so I am pleased I went t the trouble. I used 4mm ally but on reflection 3mm would have done. On the positive side, I can jack the car up on it, it's that strong!!
    Oct 2017
    Oxford
    774
    I was chatting to Jon from AK about this at Autosport and also spent some time measuring the clearance of each car on the Total Headturners stand.
    Jon suggested 75mm minimum.
    That 6 cars I measured varied from about 70mm up to 120mm!
    4,054
    They could really do with some diagrams of all their imaginary lines! That made my head hurt
    Dec 2011
    Rugby,West Midlands.
    613
    I used to have 100mm between sump and road on my AK which is the lowest point, but has now decreased to 90mm having fitted a sump guard, and so far no problems, as long as i go in between the hump type road humps, and take it easy on the Fosse -Way . Legislation probably don't apply to private roads like NT properties, and retail parks ,but i'm sure they are higher that 100mm
    Paul.
    May 2005
    Sheffield
    1,027
    Mine is 61mm from the very substantial steel sump guard. My pal’s AK is the same. We compare notes on where we bottom out and often see sparks shoot out. I assumed that was fairly standard.
    Like psh we have to take the engine between hump bumps and take the wheels over two humps.
    Another chum used to catch his sump, not sump guard, on some cats eyes until he adjusted it before it was sold on - a bit too low I reckon!
    Nuf Said
    Nov 2016
    Stevenage
    280
    Watch the lower coolant hoses aswell especially on a Dax, reroute it and guard it also.
