Results 1 to 9 of 9
    Feb 2016
    111
    Expansion/header tank
    Hi Guys
    i have Chevy sbc installed in my GD. I have occasional cooling issues with air blockages
    the highest point on the system is the pipe from the thermostat housing down to the header tank so the curve on the hose sometimes traps air I have a small breather vent but don’t want to worry about it and have too unscrew it etc
    my engine builder has suggested I get made a bespoke expansion tank and run the heater hoses though this tank sited higher than the thermostat and discard the original low sited tank
    any ideas or input would be greatly appreciated
    Howard
    3,775
    I take it you don’t have the GD header tank mounted on the chassis cross brace?
    Can’t remember what it costs, but it definitely works
    Rgds
    Feb 2016
    111
    I do have the GD tank but it’s much lower than the hose to the thermostat
    Feb 2016
    111
    9,206
    that is a very tidy looking engine install.
    1,460
    Your expansion tank is far to low. The pipe needs to be flat going into the tank and the top of expansion tank height above the thermostat housing. Raising the tank will elevate the air pocket issue. A 45 degree housing will give you the height .
    Feb 2016
    111
    Ok. So a new tank made and situated at the back of the engine bay therefore higher than the stat and run a hose straight from the stat to rad which will be much flatter if I use a different housing with a straight outlet. I assume I will still need a cap in this new tank fo4 pressure release and filling ?
    1,460
    You need the cap as you say for filling and venting as it will be the highest point . Mount the expansion tank as close to the engine as.possible will give you more headroom between the filler cap and bonnet underside.. As an example the Fe427 expansion tanks are ontop of the engine thermostate housing thereby giving you a height mounting point.. Most builders have the problem of obtaining height . Another example is the Dax tank which is mounted in front of the bulk head and.slanted to give it height.
    Mar 2013
    Netherlands
    50
    125
    Hello Howard
    If you can send me a PM, I can e-mail you some pictures. I have a GD with LS and recently changed by headertank. Bought a new one for approx 65GBP
    Marcel
