Results 11 to 14 of 14
Thread: LED dash lights
    Oct 2017
    Oxford
    785
    I am pretty sure it is because the LED offers less resistance than a traditional bulb, so the fix is to put a resistor into the cable
    2,340
    LEDs present more resistance than a bulb, that's why they draw less current. Putting a diode in series will hide the symptom, putting a resistor in series will make the LED dimmer.
    Oct 2017
    Oxford
    785
    I know when I fitted an led battery/alternator warning light on my Westfield dash, I fitted a 100ohm resistor across the led terminals to stop it faintly glowing/flickering when the engine was just ticking over. Worked a treat
    2,340
    Resistor in parallel is a good idea for the ignition light not only to stop it flickering as you describe but also to help the alternator 'boot-up' cleanly if the LED does not flow enough current.
