Results 1 to 10 of 14
Thread: LED dash lights
    2,305
    LED dash lights
    I have LED warning lights on the dash, problem is, the alternator and oil pressure lights go out and I have oil pressure, but there is still a very faint light emitting from the LEDs.
    Any ideas why?
    I’m worried it will be an IVA issue in a few weeks time!!
    Oct 2014
    United Kingdom
    51
    347
    Common with most LED's. I believe you can just add a Zener diode to stop the residual current. I have the same on some other lights so may try myself when the weather improves. No idea about the IVA though - good luck.
    2,305
    Never heard of them, the two lights are on a common live then switch to earth through the respective sensor.
    I guess I put the diode in the live feed?
    Anyone else fixed the issue with these?
    8,737
    Just fitted something like this to my turn indicator on my dash which had stopped working properly since upgrading to LED rear lights....
    https://www.ebay.co.uk/i/28325732870...SABEgKcgfD_BwE
    2,340
    Putting a diode in series is just hiding the symptom. The problem is a leak to earth.
    2,305
    This is what I thought, a diode controls the direction of current flow, but if there's an earth leak, how will a diode help?
    I thought if the current flowed the wrong way the LED won't light up anyway??
    Aug 2009
    601
    A diode is usually used to stop the current reversal when using servo motors. Not sure how it will help a LED.
    It just does....
    8,737
    Quote Originally Posted by Daryn Smith View Post
    If you have a single indicator light on the dash, standard flasher cctry just lets the current flow earth through the arm of the circuit which isn't active. That won't work with LEDs due to different internal resistance. In this case, you need to add a diode to the O/S and N/S light feed, and then earth the the other side of the warning light. But that migt not be the issue refereed to in the OP.
    2,340
    A diode flows pretty much no current in the reverse direction. That's really their purpose. In the forward direction they flow current but you 'lose' around 0.7V so for the OP where the diode is glowing dimly another diode in series may appear to fix it.
    2,305
    I bought one of these for each wire, to be positioning between the bulb and the sensors.
    https://www.almsolutions.co.uk/index...b7kpnj13nk03i7
    I'll let you know if it works this weekend hopefully.
