Results 1 to 10 of 18
    Oct 2013
    Ilford essex
    132
    LT77 Gearbox - Fill plug
    I decided to change/fill the gearbox oil on what I believe to be an LT77 box. Jacked up the car to discover that there's no fill plug! Is that right or am I missing something here? There's a small leak from the drain plug and i don't know how long its been leaking. It made sense to drain and fill it because for all i know it might be empty!
    Anyone have any suggestions on how I fill it?
    Dax MK4, RV8
    Oct 2006
    Toton, Nottinghamshire
    886
    Quote Originally Posted by bigkev38 View Post
    It should be on the passenger side of the gearbox casing, about halfway up the side.
    Russ.
    1984 DAX Cobra
    Oct 2013
    Ilford essex
    132
    Quote Originally Posted by Russ-Notts View Post
    Russ.
    No fill plug just the drain plug at the bottom. I can see both sides as clear as day and there's no other plug on the black gearbox housing. I was expecting it to be above the drain plug, but there's nothing there on either side.
    Dax MK4, RV8
    2,312
    I struggled to find mine a few weeks ago, but it is there.
    It's further back than you'd think. I think it might even be on the silver rear casting rather than the darker main casting.
    Oct 2013
    Ilford essex
    132
    Can't say i looked on the silver casing I will pop out and have another look, thanks Craig
    Dax MK4, RV8
    2,312
    If you scroll down a bit, there's a photo showing it here.
    https://www.pistonheads.com/gassing/topic.asp?t=1601403
    Sep 2004
    Bressingham
    1,348
    I have seen some with the level plug not machined. I think they have a nice Leyland logo there instead.
    I suspect it is a fill once for life thing or maybe refill to quoted capacity after draining.
    The bung at the back will feed forwards as far as i remember. I think there is also a breather on the very top that could be used.
    Then of course there will be the debate about what sort of oil to use... and how much.
    Oct 2013
    Ilford essex
    132
    Cheers Craig, you were correct I found it at the back on the silver part. Unfortunately access is almost impossible. Short of removing the passenger seat and drilling a very big access hole in the tunnel there's no way i'm going to get a spanner in there. It's going in for it's MOT tomorrow morning so I will ask if they have any ideas or specialist tools. Of course having a car lift is already a good start for them, so fingers crossed.
    Dax MK4, RV8
    2,312
    If you can’t get the filler tube from the oil bottle in there, surely you can get a long, thin pipe into the hole and fill it with a funnel remotely?
    136
    I have rv8 with a fully rebuilt LT 77 gearbox ,the oil that I use is a ford MTX 75 grade ,overfilled by a half a pint.
    Some use ATF but was told by a good source that the MTX was far superior .
    The official oil to use is EP 80 grade,
    Hope this helps, Chris.
