Results 1 to 9 of 9
    Dec 2019
    amersham
    Seat belt anchorage
    Continuing with my AK build i started to look at the lower seat belt anchorage points, i purchased some 7/16 UNF eye bolts and it looks as though they screw into the existing tapped holes in the chassis,now i presume that they do need to be eye bolts as when you look at seat belts/safety harness connections they generally show a spring type catch arrangement which attaches to the eye bolt, is this the correct interpretation.
    Mar 2008
    Coventry
    2,328
    The harnesses bolt flat to the chassis with normal bolts, you need eyed for the top mounts.
    AK, on the road Oct 2012
    Dec 2019
    amersham
    Thats how i thought it might be ,but when you look at modern safety harnesses for instance in Merlin motor sport the harness end connections are all spring type catch arrangements.
    Confusing ! Also the tapped hole in the chassis lays back from the fibre glass foot well by about 7 mm which means that when you tighten the bolt whether its an eye bolt or just a plain bolt the fibre glass will crack unless spacer washers are added, not the best design for a safety relevant part.
    2,305
    These are the type of harness you need, as Paul says, eye bolt at the top, bolts at the hips.
    https://www.merlinmotorsport.co.uk/p...4w?pn=SS3X4B-W
    Mar 2008
    Coventry
    2,328
    Quote Originally Posted by methoni View Post
    My body when fitted was quite tight to the fixing holes, once the fibreglass was removed over the fixing hole a large washer was enough to allow the bolt to tighten up with no issues
    Lanarks
    255
    Eyebolts top and bottom on mine
    I think IVA chap would like to see the swinging brackets with the catch need clearance and not foul on the seat or headrest
    Dec 2013
    Newark, Notts
    69
    1,535
    When I fixed my lower bolts I made a spacer which went through the fibreglass and then sat flat on the chassis. This got over the flexing off the fibreglass
    Charlie
    Dec 2019
    amersham
    Yes
    I have come to the same conclusion,make up a spacer or use washers to bridge the gap, and having spoken to Merlin motor sport ordinary grade 8.8 hex bolts are the way to fix the lower belt to chassis anchorage points.
    Apr 2014
    Stourport on Severn
    255
    Did mine similar to Charlie.
    Used a lock nut and wavy washer to allow a bit of rotation on the belt Anchorage.
    The locknut acts as a spacer.
