Results 1 to 3 of 3
    Dec 2019
    amersham
    Handbrake mounting
    I am at the point of mounting my handbrake lever assembly on my AK kit. One thing that i may do is cut out a section of the fibre glass to clear the footplate of the mounting bracket, the reason being that when the body is lowered onto the chassis in theory there is a gap caused either by the sealant or foam strips which seal the body to the chassis.
    The advantage in doing so ensures the bracket has a firm base to fix onto in other words metal to metal contact. Another modification which i may investigate is to slot the fixing holes to improve lateral adjustment,once all is finalised and the brakes are working as they should be a 5 mm roll pin can be added through the bracket and into the chassis as a permanent
    fixture thus stopping any movement.
    Cutting the hole in the body in my opinion does not represent any weakening in the shell.
    258
    Donor car XJS lever with shortened cable
    Dec 2019
    amersham
    I like the idea showing multiple holes in the base of the bracket to enable the bracket to move giving extra adjustment on the cable.
