Results 1 to 8 of 8
    Oct 2013
    Ilford essex
    128
    Speedo Magnet positions
    I have a Stewart Warner speedometer. It stopped showing the correct speed last year, always displaying 20/30 miles below the actual speed.
    I got under the car to look for the speedo sensor magnets and have found two, one of which is not glued on and is clearly in the wrong place.
    How many magnets do I need and how do I know where to position them? i.e. Should they go at 12 a'clock and 6 o'clock using 2 magnets?
    or 12, 3, 6 and 9 o'clock using 4 magnets? Or is it more complicated than that and I need to make some kind of calculation to determine their position?
    Thank you
    Kev
    Dax MK4, RV8
    Better to try, and fail....than to fail to try.
    9,521
    You can use as 2,3 or 4 magnets as long as they are evenly spaced. You must calibrate the speedometer accordingly though for whatever you choose, most speedometers are programmable if you look in the manual for it.
    Oct 2013
    Ilford essex
    128
    Thank you, very helpful. I will glue them back on!
    Kev
    Dax MK4, RV8
    9,521
    If you are using araldite to glue them on make sure it's the slow set varity as the quick set version isn't strong enough 9i lost 3 magnets before i found this out or sikoflex works a treat.
    Oct 2013
    Ilford essex
    128
    Quote Originally Posted by TINKA View Post
    I read somewhere on here that sikoflex is good so I will give that a go, thank you
    Dax MK4, RV8
    Oct 2013
    Ilford essex
    128
    It seems from some searches that Sikoflex is a sealant. Is that the stuff I need to fix the magnets or is there a glue version?
    Dax MK4, RV8
    9,946
    Kev.
    Sikaflex is an adhesive as well as a sealant.
    Once dry it takes some shifting, it's really useful stuff.
    1965 Ford Mustang 289 Convertible FOR SALE
    In build- Hawk 289 Sebring
    Mar 2010
    Hertfordshire
    917
    +1 for the old slow Araldite. Mine have been attached now for over 10 years with that
