Results 1 to 6 of 6
    Mar 2005
    BERKSHIRE
    642
    Wanted,edelbrock,carb,choke,linkage
    WANTED EDELBROCK CARB CHOKE / LINKAGE
    Hi all just wondering if any one has the choke flaps and shaft and choke linkage for a Eedelbrock square bore carb 1404/1405/1406 type
    or a scrape carb for parts
    ps / what is this Tag bit all about ?
    The number of tags you tried to add exceeded the maximum number of tags by 1.,,,,what ?
    Peak District
    193
    I have got a spare Edelbrock carb. I'll have a look and see if it is any use to you.
    The one part it doesn't have is the actual choke flaps and linkage though. from memory, i think it has the shaft.
    The reason why i didn't use it was because it didn't have an automatic choke.
    cheers,
    Mark
    Peak District
    193
    cheers,
    Mark
    Mar 2005
    BERKSHIRE
    642
    hi di you have a look for the linkage parts mark ?
    Peak District
    193
    I've managed to find the unused carb. It's a 1407 though.
    It appears it's the shaft that it's actually missing. My memory is obviously failing me because it has an automatic choke as well. Jusdt not all the parts needed to get it working.
    Hopefully the link below works for photos.
    https://photos.app.goo.gl/t5YpE8WuQn1kZ1R2A
    Mar 2005
    BERKSHIRE
    642
    pm sent mark
