    Jun 2016
    Shawbury, Shropshire
    66
    AK air filter choice.
    Hi all,
    I’m looking at options of an air filter that’ll fit my AK. I’ve got a Chevy 350 with a FiTech EFI and just wondering which ones will fit over the FiTech and also under the standard bonnet scoop. I’ve tried the 14” black Edelbrock one from Real Steel but even if I’d ‘modified’ the bottom of the filter housing with a hammer I wouldn’t get the bonnet shut. Also the FiTech has a different size thread to the standard mounting threaded rod. There are adaptors available from summit racing in the states but also wondering if anywhere in UK sell them too?
    If anyone has this setup which filter did you use or if anyone could offer some advice it would be much appreciated.
    Thanks in advance guys
    Mar 2008
    Coventry
    2,335
    You will need a dropped base air cleaner to get the clearance needed, you may well have to trim it here and there to clear the carb
    AK, on the road Oct 2012
    1,168
    As Paul says you need one like this.
    https://www.youtube.com/watch?v=5osW9Fi4JTE
    Jun 2016
    66
    Thanks guys, that’s a good starting point. I’ll have a mooch on t’interweb and see what’s about.
    Jan 2016
    Middlesbrough
    70
    I used one from Real Steel - Mr Gasket Low Rider 14" - part no BY4339
    Jul 2002
    Curridge, Berkshire
    885
    I have a drop base K&N 14” filter (pn#60-1280 - 14”x3”, 1 1/4” drop base) that’ll fit a 5 1/8” flange that I didn’t use in a recent rebuild. Bought originally from RealSteel.
    Open for an offer if this’ll work for you
    James
