Results 1 to 10 of 11
    Mar 2019
    Sevenoaks
    85
    Oil everywhere!!!!!!
    I cant believe it!!!
    Just prepping the body to go off to paint and whilst lying under the engine i noticed a couple of drops of oil on the floor..
    on closer inspection oil has dripped onto the anti vibration cam at the front of the engine and then been thrown around the engine bay!!!!
    Will anything go right at the mo!!!!
    So at the moment i cant see if it is leaking from the crank case or somewhere else on the front of the engine. I just came in doors and feel very depressed and low.....spend all the money on a new (refurbished/stroked 350 chevy) engine and now i have a leak to solve and deal with.
    I guess first thing is to clean everything up.
    Then run the engine and get under the car to see where the leak is coming from......it can only be when the engine is under pressure as no leaks prior whilst sitting in my garage. I have only run the engine up 4 times and no longer than 30 mins combined total. Son and i did a cheeky couple of runs up the road last weekend 1/4 mile in total.
    Interestingly you will see one of the photos of the cross member in front of the engine/belt has oil all over it.....how does oil get in front of the engine? Is it squirting out of a hole?
    What is the first thing i should look at .......what is the most common error......thank you. I attach a link to the video i did of it below.
    https://photos.app.goo.gl/AUuVpqvBuzoRgEgt6
    B*ll*cks!
    Julian
    AK Cobra started 06/19
    Chevy 383 Stroker, TKO 600
    Aug 2009
    610
    First thing to do is clean all oil off the engine and chassis, run her up and then just keep an eye on the engine so you can spot where the oil is coming from.
    It just does....
    Nov 2008
    Guildford
    346
    Are you sure its oil and not coolant?
    Nov 2008
    Guildford
    346
    Quote Originally Posted by Flykilla View Post
    Sorry just watched the video and its definately coolant.
    3,677
    You must be looking at a different Video - that is oil.
    Chin up Julian, identify it first then worry about how complex it is to fix afterwards
    GD J1M
    Nov 2008
    Guildford
    346
    Jeez, I am on form today. I meant that its definately oil not coolant.
    Jan 2014
    High Wycombe
    668
    Remote filter or oil cooler?
    Graham.
    1,158
    You have oil on both sides so the crank is flinging the oil around.. Better having a leak at the front than the back side however bad it looks. As suggested give it a clean down. Look front crank and front oil pan. If you have a leak on the oil pan.it will run onto the crank. Check the oil pan nuts also oil filter pipes pick offs if you have fitted a remote oil cooler.
    Mar 2019
    Sevenoaks
    85
    Standard oil filter, no cooler
    STOKE ON TRENT, U.K.
    10,167
    On the front of the block next to where the fuel pump would be mounted there are two tapped (3/8 UNC) bolt holes.
    Often one of these holes is a through hole (into where the fuel.pump pushrod slides) and needs a short bolt in it to blank it off.
    Check this before you strip everything down.
    HTH.
    ‚ÄčPro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
