Results 1 to 10 of 19
    Nov 2007
    Chester
    636
    Lexus IAC rebuild
    Undertook a rebuild of the idle speed air control valve today on my ls400 engine. My unit is the non rebuildable sealed version. Took an hour to work out how to split the stepper without damaging it but in the end all ok. So for 1uzfe users it's quite straight forward and the replacement motor bearings cost £6 rather then the £300 quote for a new one or £80 for a flea bay suspect.
    Al
    Newcastle upon Tyne
    1,899
    Al,
    I have replaced the OEM Toyota Idle Air Control on my 1UZ with a proprietary unit from BHP in order to reduce the number of ECU auxiliary outputs needed to control it. The standard unit needs, I think, a four wire connection whereas the proprietary unit only needs two.
    I therefore have a Toyota IAC, for the 1UZ (removed from a 1992 engine from a Soarer), available if you, or anyone else, have similar problems. I have never run the engine with the Toyota IAC fitted but, given the excellent state of the rest of the engine (before the scrap yard got their hands on it!), I have every reason to believe it is operational.
    Still loving the 1UZ, best thing I have done to date!, so thanks to you and the others in the Lexus branch of the CRC for your help & encouragement
    Take care,
    Ian
    1,228
    You don't have a spare MAF Sensor Fuji 22204-42011 for a 91 LS400 1uz . They only have them in China or USA. Friend needs one.
    Newcastle upon Tyne
    1,899
    Jon,
    Sorry no, the engine did not come with the MAF. I was planning from the outset to run with an after market ECU that would use MAP as the input so the absence of the MAF & Toyota ECU were not an issue.
    Hope you manage to find one.
    Regards,
    Ian
    1,228
    Thanks Ian,
    I know when he fitted the engine he said it was difficult to hide the six fuse boxes and the cable harness.
    Jon
    Nov 2007
    Chester
    636
    Hi Ian,
    I already have a spare thanks, I refurbished 2 over the weekend but thanks for the offer.
    Jan 2014
    High Wycombe
    696
    Looking to do mine in the next day or two, "Kelvin" has a vid on this as well. https://www.youtube.com/watch?v=cT7Tlo0I4po
    Another couple of weeks and I should have a reasonable looking engine.
    Graham.
    Jan 2014
    High Wycombe
    696
    Hi Al,
    do you have a link or part number for the bearings?
    Thanks, Graham.
    Jan 2014
    High Wycombe
    696
    Will have to call the welding shop on Monday see if they can fix it!
    1,228
    That must of been a poor casting for it to fracture. Hope you find a local welder. That's frustrating when things like that happen.
