Results 1 to 10 of 18
Thread: Cockit heat
    Sep 2012
    Malvern, Worcestershire
    75
    390
    Cockit heat
    Hi Chaps,
    I'm getting a lot of heat into the cockpit, much of which is coming in via the heater. I took over this Classic Replicas Viper 80% complete with the heater already installed. There are no heater controls inside the car, and I can see no way of controlling it from the outside of the heater box. There is a "Galaxy" label on the top of the heater which is new to me. Google and the Viper build manual are no help. The build manual mentions a Mini heater and has two pictures, one of which looks like a Mini heater and another which definitely isn't.
    I'll fit an external tap between one of the hoses and the box if that's the only way. Anyone got any other ideas ?
    Many thanks,
    Brian.
    4,210
    I think most people fit a valve into the heater hoses as you suggested - you have to be careful of your engine coolant circuit though; some have a bypass (and therefore you can just block one hose with a 'tap') while others need the heater circuit to circulate coolant all the time or you starve an area of the engine of flowing coolant - for those I think you can get a coolant 'tap' that has a bypass in it (so either flows through the heater or straight between the hoses depending on position).
    8,943
    Can you not block off the vents from the heater outlet?
    Make sure you haven't got the heater fan on inadvertently.
    Sep 2012
    75
    390
    Thanks, Aaron, hadn't thought of that. I've not come across that heater arrangement. The engine is a 350 Chevy and the heater pipes leave and return to the front of the engine at or very near the water pump housing, so should be ok. I will block off the vents as Kevin suggests as a temporary fix until I can fit a valve.
    Thanks,
    Brian.
    8,943
    Quote Originally Posted by braincol View Post
    Thanks,
    Brian.
    If you want a valve, I've got one like this, unused - haven't needed it.
    https://www.europaspares.com/mechani...alve-16mm.html
    Make me a reasonable offer and its yours.
    9,550
    Thanks,
    Brian.
    It can happen as I found out when I accendently turned off my heater and the car kept boiling over till I worked out what had happened.
    4,210
    Yeah - I'd have been more specific about engines that applies to ... if I could have remembered evidently the Ford Windsor is on the list! I'm not actually sure about the FE, though since Kevin has a simple dead-stop valve, I assume not.
    Maybe I was also thinking of the RV8? So many obscure facts, so little memory space left...
    8,943
    With an FE, your feet will never be cold.... rain, shine or snow
    4,210
    Yeah, I wasn't actually planning on having a valve at all - and the little tiny T7 heater won't be putting out much heat I imagine. There'll be no forgetting the fan is on though, it sounds like a Dyson is stuck in the footwell!
    8,943
    If I was ding it all again I would have gone with a heated windscreen.
    The T7 is really just to keep the IVA man happy - doubt I will ever use it again for open top driving, but when the hardtop goes on, we'll see what its capabilities are like!
