Results 1 to 10 of 19
    Dec 2019
    amersham
    111
    Fuel pump position
    There is much speculation regarding the positioning of fuel pumps relative to the tank outlet. I intend to purchase a carter TP4600HP fuel pump for my chevy carburettor 350 short block build. owing to the fact that its not possible to locate the pump close to the tank outlet off i intend to position it adjacent to the bellhousing that,s approx 1.3 metres from the tank. The pump inlet would be approx 130 mm above the tank outlet.
    ideally the pump inlet needs to be close and below the tank outlet but its not possible.
    Any comments welcome.
    2,321
    As long as it’s self bleeding, I don’t see an issue (Some pumps need to orientated correct to bleed)
    Houghton le Spring
    184
    I have my carter located in the boot above the fuel tank (Dax) - not had a problem with it.
    Geoff
    155
    Quote Originally Posted by glip View Post
    Geoff
    Same here ,
    Accept mines a srv8.
    chris
    Apr 2014
    Stourport on Severn
    267
    Mines mounted as you are planning and it’s not been an issue for me.
    Dec 2019
    amersham
    111
    Thanks Gents
    I think i now know what i need to do, mount it near the bell housing, in the correct orientation of course, ideally away from any heat source and keep my fingers crossed.
    342
    Geoff
    I would be interested to see any photos of how you mounted this and the plumbing routing. I am not at all happy with the present location, two inches from a rapidly rotating shaft!
    Cheers, David.
    Wessex region caretaker rep.
    Dec 2019
    amersham
    111
    David
    When i get the pipework and fuel position sorted i will see if i can get some photos to you, of course my engine wont be running at this stage so it wont prove that the pump is delivering at optimum rate.
    342
    Quote Originally Posted by methoni View Post
    David
    Ah, right. That's why I wanted to know as the pumps I believe rely on gravity feed to it.
    Mar 2019
    Sevenoaks
    104
    I put it here. 4 Bar pressure, no problems feeding the holley 750
    AK Cobra started 06/19
    Chevy 383 Stroker, TKO 600
