Results 1 to 10 of 21
    Dec 2011
    Rugby,West Midlands.
    683
    LED Classic headlamp upgrade.
    As one of my head light units is now in several pieces, rather than just replace it with another Wipac Quadoptic unit, and keep the standard H4 55/60 halogen bulb, which as some of you guys pointed out ,produces a poor light and beam pattern, I wondered if anyone has fitted these https://www.bowerspartsonline.co.uk/...adlamp-upgrade and if so how do they compare to the standard setup.
    Or I was also wondering about swapping to Cibie H180 units ,which according to a lot of forums and reviews I have read produce a far better beam pattern to the Wipac unit, and then either fit one of the high output halogen bulbs ,from Osram or PIAA ,or preferably one of the latest branded makes of LED bulb ,such as Osram, Phillips or Twent20, which are properly designed LED bulbs that have their LED chips in the same place as the filament of the original bulb, so that the light source is correctly aligned within the reflector ,which is critical .
    Although HID kits are the brightest upgrades you can get, I don’t want to go down that route.
    Paul.
    Swindon, Wiltshire, England.
    1,853
    Hi Paul, this has been covered before on here, re: LED/HID/Halogen. You need to know the lumen output of the LED bulbs you want to use. Anything over 2000 I think it is (my previous posts on the subject will find the actual regs) and you will need self leveling and washers regardless of how the bulb aligns on the holder. Below the limit then sounds good!
    Here you go - I found it http://www.cobraclub.com/forum/showt...LED+headlights
    Actually reading it again the lumens level only applies to washer requirement, leveling is mandatory if they are LED full stop.
    HTH
    Ford 302 336 BHP 331 ft/lb's , GD JAG249 rolling!!
    Engine started August 2011.
    1st Daughter slows progress!
    www.andysgd427.blogspot.com
    Dec 2011
    683
    Quote Originally Posted by Andy302 View Post
    HTH
    Hi Andy, are these IVA regs and do they only apply to new builds .
    Paul.
    Mar 2009
    liverpool
    502
    I understand it as all cars on the road?
    Dec 2011
    683
    HTH
    I think there is some confusion between Halogen, LED and HID Xenon.
    Here is the Department of Transport info concerning HID Xenon https://www.gov.uk/government/public...-hid-headlamps
    This comments on self levelling and cleaning but doesn't say anything about light output.
    Here is the MOT requirements https://www.gov.uk/guidance/mot-insp...#section-4-1-4
    This is very interesting. Note the following
    Page 2 defines a "light source" as any bulb, LED or other means of emitting light. (LED's allowed?)
    Page 7 says that the lamps must emit light of the same intensity and colour, no limit stated.
    Page 7 also states conversion HID bulbs is not allowed. No mention of LED
    Page 8 does state that vehicles with HID or LED dipped beams may be fitted with a self levelling system and if the system is fitted it must work. This suggests that if the vehicle is NOT equipped with a levelling system then LED lights are okay as long as the beam pattern and alignment is okay.
    Ref Headlamp cleaning. If fitted it has to work with LED's and HID. If not fitted then not a failure.
    Andy,
    Before you replied to my post, I had actually discovered the LED lamps https://www.classiccarleds.co.uk/col...=8239030763615. being sold by “Classic Car LED’s”, that were mentioned within the post you added a link to, and I had already chatted to a guy called Duncan ,who owns “Classic car LED’s” ,who I think Kevin referred to , who was very knowledgeable and honest on the subject and said these LED lamps produce the same lumen output as HID lamps and basically said that there is currently no legislation on LED bulbs because they are so new, but as they have no “E” markings , they are technically illegal , but will pass an MOT ,because they have been designed to mimic exactly the size and design of the existing H4 halogen bulb, which means the LED chips are in exactly the same place ,so that the light source is In the correct position relative to reflector. If you look at an enlarged image of the LED in the attached link, you can see graduations around the base, which allow you to twist the bulb round in order to get the beam pattern perfectly level. He also said that he has fitted these LED’s inside the Lucas head lamp unit which utilizes a smooth reflector and the optics type lens and uses them in his own cars .He said he has never had anyone flash him as they produce the correct beam pattern, ie Step, Hotspot and cut-off, which extends further and brighter than the high output halogen lamps being sold.
    Apparently Valeo bought out Cibie and they no longer sell the Cibie H180 lamps, so as these LED lamps produce more light than the high power halogen lamps, I am very temped to give the Lucas headlamp /LED bulb combination a try as they should pass the MOT and more importantly let me see where I’m going at night down dark country lanes..
    First of all I will fit just one lamp leaving the existing Wipac unit with the halogen lamp in place and compare the beam pattern and brightens between the two. Then once I have driven it at night a few times, and I will even go as far as to have a friend drive towards me and give me his opinion , I will then give you guys my verdict , but if they do dazzle other road users , I will replace them with high power halogen lamps .
    Paul.
    1,853
    As far as I can tell the IVA regulations are based on the corresponding ECE regs. One thing to look at is Addendum 47: Regulation No. 48, this covers changes to the regs to catch up with LED lighting, DRLs, AFS etc. Now the ECE regs are type approval regs for new models and in my world that's what we have to follow, how it applies to the aftermarket is unclear. What we can say is that both the MOT and .gov pages you linked to are somewhat out of date for what is on the roads today. HID is now old technology that is dying out, LED is now more widely used. Construction and use regs and the UK lighting regs are similarly way behind the times with 1989 being the most recent update of the latter. One thing that is clear in the lighting regs is that no road user shall permit to be used on the road any lighting which dazzles other road users. Not sure where that leaves us TBH!
    9,063
    Think it means those bloody awful HID units can be sent to landfill.
    I hate people that use them.
    Maldon Essex
    337
    Kevin, you sent me a PM but I cant reply as your mailbox is full.
    9,063
    Thanks James, now cleared!
    4,262
    /me pats the factory fitted HIDs in the BMW and Range Rover
