Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
    3,731
    Quote Originally Posted by drammyboy View Post
    Nearly nearly there.
    Still to pull a thinish mould from my top which I'll use as the inner skin.
    and then into paint.
    My head can’t compute that How does it fit inside if it’s taken from the outside (apologies if it’s blastingly obvious)?
    64
    538
    KevW
    See #8 2nd photo
    See #14 1st photo
    HappyJim
    Have another think about it after see my double skinned bonnet
    Jan 2015
    Paignton Devon
    419
    Don't know if that helped Jim but it made things no clearer for me!
    64
    538
    How can the larger outside (thin moulding) fit inside when it is slightly wider and longer.
    Trim it to fit plus it is very flexible......
    It will take up a slightly different profile inside.....the void space would taper.
    Might fill up this space with 2-part expanding foam.
    Hope this solves the conundrum
    3,731
    Quote Originally Posted by rpm015 View Post
    Nope, not a jot
  6. #26
    3,731
    But this helped.
    Got it, so the “thin layup” is what gives you the flexibility - clear now.
  7. #27
    9,084
    I used the same trick (in reverse) when I made white GRP footwells for my Crendon.
  8. #28
    Jan 2015
    Paignton Devon
    419
    Shame you’re not closer, you could of done one for me
  9. #29
    9,084
    Quote Originally Posted by StewbieC View Post
    Attachment 38861
    Roll bar, no problem.
    you need a Claytonrite seal to fit the rear screen measure the top flange thickness and the screen thickness and order away.
    I got mine from Phoenix Trim, they do loads of different profile seals.
    Hi Stu - what rubber strip did you use for the lip that goes round the rear of the hardtp where it meets the rear deck on the body?
    thanks Kev
  10. #30
    64
    538
    thanks Kev
    I'll be using a roll of 25x6 stick on sponge for the flange
    and a bit of door draught excluder on my hardtop windscreen channel
    BUT.......where can I get a suitable UK rear screen rubber for my top ???
