Results 1 to 10 of 11
    Dec 2019
    amersham
    115
    Repeater Indicators
    Just bought a set of repeat indicators with a black wire and a white wire, would it be correct in thinking that the black wire is earth and the white wire live, its a sealed unit so its difficult to see where the wires go on the bulb.
    Black generally would be used as the earth but with so many of these items manufactured in countries where standards are few and far between its not always the case.
    Any solutions appreciated
    170
    It should not matter which way they are wired if they are normal bulbs due to not being polarity conscious.
    However if the holder is metal that could be the earth side.
    Dec 2019
    amersham
    115
    Thanks Chris
    Yes, thats the problem, because they are a sealed unit its difficult to see the holder, i think your comment about polarity is valid, all i can do is wire them up and see what happens, at the very worst a fuse might blow.
    929
    I think I'd try an ohmmeter and find which wire goes to which contact.
    As previously said, it doesn't matter much, but if the bulb has a center contact (for +) and an outer (-) contact, wiring traditionally might make one more satisfied with the complete job... or it might not.
    I think I'm a bit obsessive-compulsive...
    Cheshire
    51
    331
    Plus if you replace it with an LED type in the future, polarity could be important.
    10,061
    I've just fitted a pair of LED repeaters on mine.
    I assumed that the black wire was earth or ground, it wasn't!
    Like yours mine have a black and a white wire.
    Luckily they still worked after I reversed the polarity.
    In build- Hawk 289 Sebring
    Dec 2019
    amersham
    115
    Just goes to show, dont take anything for granted,you would think by now that there would be an international standard for wiring colors and there applications ie black for earth,red for live and blue for neutral, but in this modern world and with so many manufactures from all parts of the globe there is no common standard, car wiring seems to be the worst with little or no instructions. i rest my case.
    170
    Some like buses, coaches and armed service vehicles used
    one colour only, usually black.
    The wiring was usually number coded but often faded or missing when needed,
    You then new where you stood !
    Dec 2019
    amersham
    115
    Well i took off the indicator unit and connected the wires directly to a spare battery and with black on the positive the bulb lit up, with white on the positive nothing, so its sorted, you would have thought it would have been the other way round ie black to earth.
    170
    Quote Originally Posted by methoni View Post
    Good that it's all sorted.
    The bulb/illumination being used must either be an led or has a diode in the unit .
