Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 162
  1. #21
    Jan 2003
    Sunny Redditch....I lied.
    271
    Hi Chris, well at the rate your going I expect to see it on the road in the spring lol. Great to see the picture's, keep them coming. Take it easy.
    Bob
  2. #22
    4,687
    As well as the engine, there are masses of BMW parts on this car. I am betting these brakes are BMW too. Anyone know for sure?
    Definitely ATE brakes, but those have been on a lot of things - Jags included.. the anti-rattle spring is on back to front, but I'm assuming that's because you're part way through disassembly here There's something off about the way the caliper is sitting, too, like it's missing or unbolted at the top most slide pin?
    IIRC they are an unusual thread, incidentally. M9 maybe, or M7. I had to buy a tap to clean a set up once, I remember that much!
  3. #23
    526
    I think I had already half dismantled it when I took the pic!!
  4. #24
    4,687
    That would explain it
  5. #25
    526
    Onward then.........So here is a pic of the UN1 gearbox which was mounted quite cleverly to an adaptor and then to the BMW's bellhousing. The shaft appears to have been upgraded to a big spline. It wobbles though, even when the adaptor plate is secured. I know little about these gearboxes but I do have another one and that shaft is solid! Something to look in to. Maybe another bearing to carry it. It seems odd to rely on the crank bush to hold the input shaft steady. Anyway, I'm not yet sure what I am going to do. Good news though is that it is the 3.44 ratio diff which I am reliably informed is the best one to have!
    And the bellhousing
    This allowed the UN1 to fit up to the BMW engine
    Now for the funny bit. When I took the clutch out I could see the printing on the drive plate as I removed it. New clutch I thought, but look at this....
    Centre spline welded in to accommodate the bigger input shaft! Don't think I will be using this.
  6. #26
    526
    So on to today's work......
    There was some pretty nasty welding on the suspension components. Shame, as they are well made and appear to be a good design. I forgot to say that I checked the car dimensionally before I started messing with it and it was good. Needed to tidy up the components though. Started with a set like this..
    And eventually got to this which is much tidier. Not sure whether I can be bothered to polish it all up any further but I have ordered a new kit to give it a go.
    They certainly look a lot better. Not as good as a lovely tigged up job but will definitely do for now. I am planning to get this car 80% (to my!) standard, get it on the road and then gradually improve it. I am trying to use as many parts as I can to keep the cost down and to frankly avoid waste. It won't look top drawer 'out of the box' but I can always improve it later, tig up suspension, change the hub carriers for aluminium etc. As we all know, there is no end to what you can do or spend!
  7. #27
    1,560
    Doing a fine job of cleaning those suspension welded parts up. Smoothed out welds look good or nice pooled tig welding can look like art work when done by skilful welder.
    I think I would look at replacing those drums for discs as I would want to make sure I have good stopping power with V8 power.
    You certainly making good progress. Like the posts and photos.
  8. #28
    526
    Thanks Jon. Agree on the brakes. They are discs though, that’s the handbrake with the shoes which run on the inside of the disc (already removed in the pic).
    It will never be a show winner but I hope to make it a decent car. Bit of a head scratcher though. Although the chassis and suspension is well designed there was no thought given to how the panels or body fitted. Particularly in the bulkhead and behind the front wheels. I am having to overcome that! Nothing in the same plane. Means I might have to weld up ally panels to make a decent job of it. Thinking about it now! Needs to be watertight too. Enjoying it though. Sure is making me think!
  9. #29
    Essex, UK
    4,107
    A word of advice if you’re interested.....make the interior as comfortable as possible (sound proofing, nice carpet etc) the GT40 is obviously first and foremost a race car and the deafening noise, heat and rain ingress ( added to the tiny windowflaps) means it very quickly gets ard work and tiresome to drive on the road.Add these things as you’re rebuilding it, you’ll thank me later.....
    having owned examples of these, the quiet, more refined cars were used much more than the loud, laity ones.
    simon
  10. #30
    526
    Quote Originally Posted by simon View Post
    simon
    All advice and experience very welcome! That makes total sense. I have to make a decent job of the inside as the wife is telling me it should be something she can drive! (Not like my cobra!!). She has already chosen red leather! Eek!
