Results 1 to 10 of 16
Thread: Horn issue
    Dec 2015
    Walsall
    168
    Horn issue
    Having issue with the horn not working, tested the 2 cables to the horn 1 is earthed which i have tested. The other goes back to the pin on the column under the steering wheel which i have also tested but should this be live.
    Any ideas.
    Mar 2005
    1,239
    Has the horn itself died ? Run alternative earth and alternative +12V to the horn from the battery and see. I’ve had a number of horn units stop working. Also, is there a relay in the +ve side which may be duff ? Otherwise my guess would be an earthing issue - I learned this from the Master - Denis Ooglyoodoo.
    David (AKA Firestarter29)
    Oct 2006
    Toton, Nottinghamshire
    900
    Hi
    You also seem to be having problems with your Smiths oil pressure gauge, http://www.cobraclub.com/forum/showthread.php?t=62781.
    Could the two problems be related, be it a poor 12volts or voltage regulator fault?
    Seems a bit suspicious to me.
    Russ.
    1984 DAX Cobra
    Apr 2014
    Stourport on Severn
    306
    Check out this thread
    http://www.cobraclub.com/forum/showthread.php?t=60584
    there are some good descriptions of how the horn wiring should be.
    2,369
    Quote Originally Posted by RCAK View Post
    Any ideas.
    Of the two wires on the horn, one is live, the other switches to earth through the steering wheel.
    At the steering wheel the plunger should be live (with the horn connected).
    I had to fit a jumper wire on mine to leap over the rubber connecting boot on the column.
    You need to assume that the column earths through the rack, so it needs an electrical circuit from the steering wheel to the rack.
    Dec 2015
    Walsall
    168
    I have tested the 2 wires to the horn 1 is earthed but the other isn't live but it does go to the pin plunger on the column.
    2,369
    Are you using AK’s loom??
    I’m almost positive one of the wires on the horn should be live (with the ignition on), the other should be earth (but only when the horn is pressed).
    The live should be the one that DOESN’T go the column.
    Dec 2015
    Walsall
    168
    yep AK loom
    2,369
    Stupid question, sorry, but you had the ignition on and no fuses blown?
    What colour are the wires on the horn, both should be black/blue??
    Dec 2015
    Walsall
    168
    yep checked that, both black/blue cable.
