Results 11 to 17 of 17
    Essex, UK
    4,043
    Change to a magnetic sensor (under a tenner on RS components website)
    2 magnets glued onto the prop, a substantial bracket and bobs your uncle.
    Yes, very probably too many pulses.....
    Simon
    Cambridge
    36
    1,204
    Quote Originally Posted by aksportscars View Post
    If you have the 3 bolt flange on the diff then make a new bracket so the sensor points at the flange casting ie the 3 curved ends of the flange and not the nut heads, you can get a much more accurate and even distance from these points , no more than 2mm. Your problem is it is loosing the signal so you either need to do as i described or move the sensor closer.
    Jon
    AK
    Here's one I made earlier!
    Dave A
    1,794
    The Tremec gearbox is supposed to have an output for the speedo. Anyone know what’s involved in using that?
    4,304
    Allegedly.. you can just hook it right up to the input on the speedo IIRC; one to the speedo, one to ground..
    Mar 2020
    Fleet
    19
    I have a thread open about this just below:
    TKO 600 \ 500 to Smiths Speedo
    Seems to work but currently thinks zero is 40, so need to try different DIP switch settings...
    1,794
    Quote Originally Posted by Russhowell View Post
    Thanks for that. My speedo is ETB but I would guess you still need the basics to calibrate like diff ratio and tyre revolutions per mile.
    Peak District
    364
    Quote Originally Posted by hifihedgehog View Post
    Dave A
    That's really handy. Thank you.
