Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
    Aug 2008
    Hawkhurst, Kent
    244
    Locking rear brakes
    Hi ,
    I had a IVA test today on my Ram cobra at Gillingham.
    it went pretty well to be fair but failed mainly on rear brakes locking up before the fronts on a dynamic brakes test.
    Any ideas on how I could sort this? It’s on Jag inboard discs. Would a proportioning valve fix it?
    Ben
    Always in the sh*t, just the depth that varies !
    AKA The Silver Fox
    Maldon Essex
    346
    Yes it should fix that and I think that mine had one but I have now changed the pedal box to a tilton with a bias bar so I don't need one.
    1,363
    Check you have the routing correct to the master brake cylinder as the piston is split to forward bias to the front first. It could be simple as switching the connections.
    2,441
    This is a 'known' thing for the Ram. You fit an adjustable bias valve but in the front circuit rather than the (conventional) back circuit.
    2,441
    Actually, I may be completely wrong here - you have the opposite symptom to the one Adrian (from Ram) described to me years ago.
    383
    What master cylinder are you using? Maybe as suggested before, the pipe connections to this could be arse about face.
    David.
    Wessex region caretaker rep.
    10,102
    I've had to use a proportioning valve on the rear brake line two of my previous builds.
    I think from a Sierra or Mondeo.
    Don't forget it can't be adjustable for IVA.
    Essex, UK
    4,042
    Had exactly the same thing atGillingham. Fitted an adjustable proportioning valve which was the cause of my second fail!
    after lots of head scratching, I discovered the rear pads had been contaminated and were ultra sticky. Fitted a new set of normal pads and it flew through....alway check the obvious/cheapest fix first!
    simon
    Sep 2004
    Bressingham
    1,354
    You could reduce the surface area in contact with the disc by adjusting the pad with a grinder.
    Mar 2009
    liverpool
    507
    For using an adjustable bias valve, my understanding is that it's ok for IVA if after it has been set. The adjustment is rendered inoperable. i.e. the adjustable knob shaft is cut off flush. So it can't be adjusted.
