Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
    Peak District
    366
    IVA Wing Mirrors
    Evening folks,
    I'm after a bit of inspiration / ideas. One of the marginal pass/ fail items during my IVA were the wing mirrors. They are currently fixed to the top of the dors and not the windscreen frame.
    I'm wondering changing the car so they aren't a potential fail item.
    These are the type currently fitted.
    https://www.carbuilder.com/uk/stainl...ror-pair-145mm
    I'm wondering if anyone has fitted mirrors to the windscreen frame that are suitable for the IVA but don't damage the windscreen frame or need to have any further holes drilled into the frame. Oh, also they would need to be cheap as well!
    Mark
    1,368
    Hi Mark, which kit are you building?
    Lee
    Peak District
    366
    Morning,
    It's a Dax but i'm using a Brasscraft windscreen bought from Europa. It's got the 2 screwholes intended for the windwings that i could use. Onother idea would be if there are any clamp on wingmirrors available that are IVA friendly. The ones i currently have are IVA friendly (radiused edges and de-formable) but the visibility is pretty appalling when mounted on the door tops. I could relocate them to the windscreen and try to find the correct screw sizes to tap into the existing wind wing screw holes.
    Thanks,
    Mark
    Nov 2004
    Portsmouth, Hampshire
    343
    I wanted an old style look and managed to get these through IVA although the tester was very uncertain until he confirmed everything . Bought the mirrors on CBS and made the mounting plates but you can buy them.
    Peak District
    366
    Quote Originally Posted by pevans View Post
    Are these the ones?
    https://www.carbuilder.com/uk/lightw...polished-100mm
    Nov 2004
    343
    yes those are the ones. I was a little worried that they would not comply but they do have the right sized mirror surface and are rounded. I did put trims on the mounting plates I made and heat shrink over the thumb screw to be sure there were no radius problems.
    This picture might be clearer.
    Peak District
    366
    Just a thought. Do you know what size the screws are that hold the bracket onto the windscreen frame? I could re-purpose the existing mirrors onto brackets similar yours.
    Mark
    Oct 2017
    Oxford
    932
    I think the screws are 2BA thread, hopefully someone can confirm
    Lanarks
    64
    554
    Drill 1 extra hole and tap 2BA
    Use 1 of the existing holes on the support frame to give you the 2 fixings required.
    Peak District
    366
    Thank you for the help everyone. It's very much appreciated.
