Results 1 to 7 of 7
    Jan 2014
    High Wycombe
    729
    Acoustafil and welded exhaust pipes?
    Afternoon all,
    Just managed to bag myself a set of stainless steel exhausts on the Bay of E.
    Apart from needing a serious polishing session they are not too bad for what I paid for them. However thinking in front, I was looking to fit/wrap acoustafil when I get to IVA (not for some time yet) to help with noise levels and I have read it does make the exhaust tone sound better and helps with heat insulation, the problem is though they are welded from front to back ie no joints that come apart. Has anyone come across a similar exhaust set up (or know who might have made them) and if so how did you get access to the innards? I can see the back end of the inner pipe but no obvious way of removing it to clean or repack!
    As always any thoughts welcome.
    Thanks, Graham.
    Can't delete the expansion tank photo, weird!
    9,159
    Think you may need to chop the ends off, resleeve and rejoin.
    You should have a perforated tube that runs down the inside centrally. The acoustifil is wrapped around this and slid in. Then fit re-sleeved end cap, held in place with a couple of small bolts.
    Sorry, probably not the answer you wanted.
    10,119
    The original Dax pipes used to be welded like that.
    I had to cut them open and modify them similar to the later ones to make the baffles accessible.
    As well as noise you'll need to think about radius's too.
    Jan 2014
    High Wycombe
    729
    Radius's are ok in as far as the outlets/tips are actually radiused, haven't measured them yet but they "look" ok.
    Perforated tubes are present both sides but I haven't poked around inside yet to see what's holding them in, and haven't looked to see if there is any kind of wrap. Both jobs for tomorrow.
    I had hoped that they would have a removable end but can't complain as they were cheap and they're stainless so plenty of good points. As far as chopping the end/s off I think that's probably the way to go, could anyone recommend an end? I'm thinking the front as I need to think about installing cat's to cover emissions later on (engine is a 1996 Lexus). I would like to fit them in the pipes but have also read on plenty of threads that one bracket (rear) on the exhaust is the way to go, so how does that work if the front of the exhaust is just bolted together?
    As always more questions to work through but for now I'm happy, they're stainless, mine and look (will look) pretty damn good.
    Cheap as in £100.00 for the exhausts, £60.00 pick up and deliver 24hr door to door (TNT ouch) and £20.00 for a polishing kit.
    Graham.
    Jan 2014
    High Wycombe
    729
    So an update,
    Chopping up a perfectly good set of exhausts is a bit of a leap for me so I decided to start with a clean up of the welds to get them nice and flat before polishing and found this mess hidden away below;
    Not quite what I had expected and five minutes later they look like this;
    What I have are 4" pipes with an 80cm x 2 1/2" perforated tube (possibly wrapped) welded from top to bottom inside and out, badly!
    Plan of attack is:
    1. remove all the gubbins from inside, bin it all and clean up the inside edges.
    2. order new stainless steel perf' tube (sticking with the 2 1/2" diameter).
    3. order 4" stainless steel cones.
    4. order or fabricate a stainless steel mounting plate (big washers) for the rear of the perf' tube.
    5. order or fabricate some sort of stainless steel sleeve so I can reattach (and remove) the outlet.
    6. figure out how to bolt the rear of the exhaust and rear perf' tube mounting plates to the rest of the exhaust and not have it look like sh*t.
    7. order acoustafil and rewrap everything.
    8. visit the local welding shop and have it all put back together.
    8 probably before 7?
    Did I miss anything?
    Not quite what I had planned but I still end up with a decent pair of stainless exhausts that didn't cost a lot.
    Graham.
    1,385
    The problem that usually occurs is the perforated tube ends up loose and creates rattle problems if it's not secured properly in the tube.
    396
    Thats the problem I have with my Dax pipes. They both need tearing apart and rebuilding. And only 7000 miles on them!!
    Wessex region caretaker rep.
