Results 1 to 10 of 27
    Dec 2011
    Rugby,West Midlands.
    696
    dip tube conversion problem
    Even though I have now got a Spiyda fuel gauge wizard fitted ,I am still having problems with fuel slosh affecting the fuel gauge and intend fitting a VDO dip tube sender and matching gauge, but the flange on VDO dip tube senders have 5 holes on a 54mm pcd, and the AK tank sender hole has 6 holes on a 60mm pcd. How have other people overcome this issue when you fitted your VDO dip tube .
    Does anyone know if there is an off the shelf converter /adaptor plate i could buy, to save me getting one made.
    Paul.
    Mar 2008
    Coventry
    2,351
    Paul,
    there is a damping mode on the spiyda gauge, just turn that up. Instructions tell you how to increase this
    AK, on the road Oct 2012
    Dec 2011
    696
    Quote Originally Posted by seph View Post
    Paul,
    Paul,
    I have tried all the settings and the highest setting does damp it the best ,but its still slowly deviating by about 1/4 tank, between vehicle stationary and cruising. Tank will read 1/4 tank stationary ,then slowly climbs to 1/2 tank while steadily cruising ,especially when its below 3/4 of a tank. Above that ,its rock steady ,really annoying
    Last time i spoke to Tinka ,he said he was also having issues with his Spyida/Dip tube setup, and i have tried to PM him, to see if he has solved it ,but his inbox is full, so if your looking in Martin, empty your inbox mate.
    Paul.
    Mar 2008
    Coventry
    2,351
    Paul,
    it may be worth a call to Spiyda to see what they recommend. My float based one has no issues
    Mar 2009
    liverpool
    513
    I have just been setting my one up at the weekend. Odd shaped tank with EDO float arm sender and the gauge wizard. Once all set I changed the anti slosh to the middle setting. Thought this was too much when I operated it, so set it lower. Will see when on the road. My float arm is left to right, so anti slosh on cornering. Is your sender at the rear of the tank? As it maybe the fuel going to rear as you are going forward. Causing the increased reading. The anti slosh will just cause it to take longer to show, but when you brake the anti slosh won't let correct as quickly. Then you are accelerating again, so keeping the higher reading?
    1,811
    Quote Originally Posted by psh View Post
    Paul,
    Sounds like it’s a voltage stabiliser issue. Is there an inbuilt one in the gauge? You could always use my “fail safe” solution Paul. A bit of wooden dowel to dip the tank. Never lets me down!
    Dec 2011
    696
    Paul,
    Yes, worth a go .
    Paul.
    Dec 2011
    696
    Yes i follow what you mean about the too higher anti slosh setting , not allowing the gauge to adjust quickly enough ,thus keeping the gauge reading high, but i have tried all the settings and setting number 8 gives the most stable results . If the sender was at the back of the tank ,i would agree with your theory of the fuel bombing to the back while the car is on the move, causing the float to rise ,which would be down to poor baffle design , but its at the front, on drivers side, and i think its orientated front/rear.
    Paul.
    Dec 2011
    696
    I use a dip stick to check the coolant expansion tank level. I dont fancy stopping the car every 5 miles to dip the tank
    All the gauges on the AK run through a voltage stabiliser ,which was replaced with a brand new one ,when the wizzard was fitted.
    Paul.
    2,448
    Doesn't sound like a slosh problem. At a steady speed cruising along there is no acceleration and very little slop.
