Results 11 to 18 of 18
    Feb 2010
    Essex
    244
    Hi Mark - sure thing I will be hoping to drop the sump this weekend if life doesn't get in the way and take some measurements so will up date this thread
    AK Gen 1, SBC 350, 3.54PL Diff, Getrag - Build Start 03/09/2010 Passed IVA 01/09/2014 On the Road 01/10/2014
    Dec 2009
    Barton Mills,Bury st Edmunds,Suffolk
    329
    Hi Barry I’ve just measured the sump that I’m going to fit and Sod’s law it measures up as needing the thick gasket and I’ve got the thin! Doh ! I just thought whilst in lockdown I may as well do mine as it hasn’t been run for 5 months so should be a clean job!! I now need to try and get a thick gasket!
    so I may have a thin gasket for sale ?
    Mark
    mark chambers
    Dax de Dion 350 Chevy
    Feb 2010
    Essex
    244
    Thanks Mark. I have a feeling (to be confirmed) that i may need a thick gasket also as I came across an email of 8 years ago from my engine builder that says whilst the block is 1973 all his builds use a timing cover and sump for a 1975- 79 hence the thick gasket - watch this space
    Jun 2016
    Nantwich Cheshire
    315
    Quote Originally Posted by mark chambers View Post
    Mark
    Mark, I may have a 1 piece thick gasket in the garage. I will check later.
    Feb 2010
    Essex
    244
    Quick update all - Oil Pan removed without much effort, measurements 2 3/8" depth and 5 3/4" width so that aligns with the Thick Seal according to Summit
    May 2012
    near Thame
    185
    I did find this on eBay
    https://www.ebay.com/itm/321767775191
    I've not ordered it as ended up using the infills from real steel and plenty of RTV. which so far seems to have worked well. Not sure how easily it'll come off yet but am hoping it's on for a good while 🙂
    Dec 2009
    329
    Hi Barry got mine stripped yesterday and it measures to be the thick also, the sump was tricky to get off and really well sealed but seems to have been leaking from the rear. Gone all out and ordered a new sump as can’t get the one I was going to use nice and straight, good luck with it.
    mark chambers
    Feb 2010
    Essex
    244
    Hi all - quick update, fel-pro one piece gasket fitted. Yet to run in earnest but looks to be good seal so we shall see. See attached info on torque settings, thought may be of interest
