    Nov 2004
    Portsmouth, Hampshire
    371
    2 1/2" diameter Escutcheon plates
    Next thing on my list. My SRV8 has a particularly large 2 1/2" diameter roll hoop. Im wondering if anyone has any ideas for getting ali or stainless escutcheon plates ? Or anything else which might work to trim round the holes nicely?
    2,464
    Get some friendly soul to draw them in CAD (or learn it yourself) and then send the files for laser cutting. Either ali or stainless. Laser cutting does not give a bevelled edge for that you might need to go with ali and a CNC router rather than laser. If they're anything like the laser cutters round here there is a minimum charge (around NZ$60) so it may be work getting other stuff done at the same time or have several sets made and then sell the spares.
    1,379
    Hi have a word with John at Sandj motors he can make them in stainless steel or Chrome on brass stainless ones will be quicker to make give them a ring 01257 262881.
    Nov 2004
    371
    Thanks for the responses, I will try SandJ and have emailed a couple of local companies just in case.
    298
    That's my next job to do on my SRv8,
    I think I will do my own with the suggested Crome on brass,
    much easier to work with and will look good.
    About twenty five years ago I used just a piece of black rubber
    pipe connected together with a black windscreen washer connector !
    Just as a temporary means to stop water ingress .
    This was one of the lower priority jobs back then.
