Results 1 to 7 of 7
    Jan 2003
    PRESTON, LANCASHIRE, ENGLAND.
    198
    speedo calibration
    hi all
    i want to recalibrate my speedo to read slightly higher than actual speed. i know what the formula is to do the calculation but not sure if the tyre/wheel circumference should be higher or lower than to make speedo to read higher, i think its higher
    regards graham
    302
    As your tyres wear down you speedo / odometer readings read higher .
    Not easily noticed though .
    302
    You could check this over a measured mile if you have or know of one
    near that you.
    Taxis use these for there calibrations checks which are carried out
    by Hackney carriage officials.
    1,882
    I’ve got a speedometer app on my phone which I use to check my cars against.
    2,358
    Your better off using a sat nav and calibrate it to that. The sat nav should read closer to actual than the speedo in your car as they are normally set up to 5% higher than actual.
    But if you drop the pulses per mile the speedo will read higher than it did before.
    Peak District
    376
    I tried to use a speedometer app on my phone and found it really wasn't very accurate.
    Jan 2003
    198
    yes i plan to check it using my tomtom when i put car back on road next year. you have told me what i wanted to know set the pulses lower to get speedo to read higher than actual thanks
