Just in the process of sorting out my rear toe.
When I assembled the rear axle the toe was pretty much zero but once bolted up I used a laser from the rear hubs to project forward to an angle of aluminium I had over the front hubs. In the end I spoke to Andy at GD who advised that over the length of the wheelbase which is 90 inches, if you assume an 18 inch wheel the distance between the chassis centre line to the projected laser points on the front on the front should be 3.75mm less than the rears.
Im in the process of readjusting mine now to suit. Im lucky that I dont have the body on, its just a bare chassis so finding the centre line and marking forward is easier.
I've also used the Rob Robinette guide and downloaded the spreadsheet to confirm. I just got to muster up the evergy to go and fart around with it again this weekend coming after putting my back out last weekend trying to do it!
Mines a GD Jag chassis but I've got late model XJS rear axle with vented outboard discs on it but the principle is the same.
