Results 1 to 10 of 10
Thread: Grub screw size
    Oct 2013
    Ilford essex
    50
    163
    Grub screw size
    Any know what size/format this screw is? Might seem an odd question given that my picture clearly shows the size as 6.30mm but I'm having trouble getting the correct size and thread. This screw holds my fake spinners onto my Image wheels, well that what its supposed to do but they keep working loose and falling off, which is proving expensive! I want to replace them with something more substantial at the tightening end as the Allen key sockets burr if tightened too much and I don't want to use Loctite as I'll never get them off again.
    Many thanks
    Dax MK4, RV8
    Sep 2004
    Broughshane Ballymena Northern Ireland
    70
    526
    Looks like 1/4" UNC
    Feb 2013
    431
    Mine are 5.92 mm with a 1mm thread pitch i.e. metric. Yours does look like 1/4 UNC to me too.
    Oct 2013
    Ilford essex
    50
    163
    Thanks Jim I will give them a try.
    Incidentally I just noticed your website and I believe that you are the guy that rebuilt my engine a few years back. I didn't own the car back then it was a guy called Brian in N Ireland. I flew over there a few years back purchase the car and brought it back on the ferry. I've been enjoying it ever since. Many thanks, Kev
    Dax MK4, RV8
    Sep 2004
    70
    526
    Hi Kev ,
    Small world !!
    Sep 2020
    Wilts
    19
    Kev, don't be frightened of using Loctite. A hot air gun will break the grip.
    Feb 2013
    431
    Forgot to say earlier - I removed one grub screw from each wheel, drilled a hole through the spinner at the point where the grub screw contacted it and fitted a bolt instead. This means that even if the spinner comes loose - I won't lose it because even the loose bolt is still engaged with the spinner.
    Marlow
    70
    1,874
    Had a helecoil fitted!
    511
    Quote Originally Posted by bigkev38 View Post
    Many thanks
    I have a small issue with my dummy spinner Allen screws/bolts due to having both unc's & metrics .
    It's only been like this for over twenty five years, perhaps it's time to tap the threads and synchronise to unc !
    As for loctite, I've always use a very small amount of the blue and have not yet lost a spinner, I'm now
    touching wood.
    Never had a problem with removal either.
    Jan 2009
    Dronten, the Netherlands
    362
    Before I stumbled upon my Trigo wheels I looked at the Image wheels and planned to make a threaded alu stub on the lathe and thread the dummy spinners all the way through so they would fit the stubs, i.e. 2". Would look nice and reduce the risk of losing one if secured with lock wire or indeed with locktite.
    Best Regards, Theo
