Results 1 to 10 of 10
    Dec 2019
    amersham
    152
    Servo vacuum hose
    Fitted my Rover 25 brake servo a while back and now need to connect the vacuum hose to my 350 short block chevy. At present there is a nylon/plastic tube running from the servo and going nowhere. The tube will have to be replaced as its too short to reach any connection on the engine. The question is in the case of a short block chevy where does the tube/hose connect to , presumably somewhere on the intake manifold .
    Any suggestions/recommendations welcome.
    10,139
    As you suggest the intake manifold on the small block chevy.
    Most manifolds will have several potential outlets.
    look for blanking plugs that can be replaced with a tapping.
    Jan 2003
    PRESTON, LANCASHIRE, ENGLAND.
    198
    mine is connected into the back of edelbrock carb
    1,474
    First check you manifold for allen key plugs for the take off. You need full vacuum so be careful if taking off from the carb. There might be two ports on your carb and the lower one should be full vacuum.
    If your carb or inlet manifold do not have full vacuum you will have to drill and tap a plug hole but I would be very surprised if that was the case.
    Mar 2008
    Coventry
    2,356
    Same here, back of the carb
    AK, on the road Oct 2012
    Jan 2003
    198
    further to previous response what you need is a hose barb fitting to screw into back of carb i think the thread size is 3/8 npt but not 100% sure
    Dec 2019
    amersham
    152
    Thats interesting, i have a quick fuel carburettor , on the back there is a short stub pipe which is about 3/8" dia, as far as i have investigated it would appear that this can be used for the brake booster vacuum hose (ie servo hose). It also is recommended that its best not to tee off any other vacuum connections.
    Mar 2008
    Coventry
    2,356
    Quote Originally Posted by methoni View Post
    That's the one I use
    Dec 2019
    amersham
    152
    I think that confirms it then Paul.
    I will use that connection, just now need to get some vacuum hose from CBS.
    2,358
    I think you might need a one way valve too, also, make sure it's secured to something between the carb and the servo (for IVA).
